Off Road / 4x4 OffRoad discussion, along with 4x4 events and information.
Synthetic Winch Rope
Old Aug 11, 2011 | 09:52 AM
D45's Avatar
D45
Ok guys.......I am replacing the 3/8" steel cable on my Mile Marker 12,000 lb winch with some safer and more user friendly synthetic winch rope/line
Why such the HUGE price difference? It seems that most are Amsteel or Amsteel blue......but the price varies from $250 to $700
I am also going to opt for the larger 7/16" diameter rope, so I shold be able to spool 80'-90' on my drum;
Masterpull: $650+
http://www.masterpull.com/item.cfm?itemid=46481
Viking Offroad: $330 for an 90' length
http://www.winchline.com/vtl_wl_wst.html
Rockstomper: $258 for an 90' length
http://www.rockstomper.com/catalog/recovery/ropes.htm
Amsteel Blue: $250 for an 80' length
http://www.tellico4x4.com/product_in...ducts_id/23386
Custom Splice: $230 for an 80' length
http://www.customsplice.com/store/7-...inch_rope.html
Old Sep 1, 2011 | 11:41 AM
CTD NUT's Avatar
As long as the rope in question is using Dyneema SK75 fibers, you will have a quality, high strength rope which will have the most strength per dollar. Several of the ropes you linked are using SK75. However, you have a lot of other variations of ropes posted. The Masterpull Superline is certianly the very best and definitely the most durable as it is completely covered in a sheeth to protect the fibers from dirt, moisture and UV light. Frequently, I hear of it lasting at least 3-4 times as long because it is so well protected. But the initial purchase price sure hurts. Remember that these synth ropes are NOT durable. They will simply not last as long as cable. Small dirt/sand particles get into the rope fibers and will literally grind the rope up from the inside out. As well, some ropes are coated for UV resistance. Uncoated/treated dyneema based ropes have poor UV resistance and will degrade.
You get what you pay for here. If you find a cheap synth rope, chances are you will be getting what you pay for. I would suggest chatting with Masterpull on the phone. They are at the top of their game and can help you select the rope that best suits your needs.
Old Sep 3, 2011 | 10:28 AM
D45's Avatar
D45
I bought some 7/16" x 80' Amsteel Blue rope from Custom Splice
Smoking good price and rated for 21,900 pounds
Old Oct 12, 2011 | 08:03 PM
solar1's Avatar
I've got a Masterpull 3/8" -125 ft on my Jeep and have been really pleased with it. I have ran it for about 6 years and worked a lot of rock crawling comps doing recovery here on the right coast. Rope is a lot safer and stronger in a lot of cases but you do have to take care of it a lot better than cable.
With that being said, I wouldn't hesitate to drop another wad of cash on another MasterPull rope.
Sent from Sputnik. Please send more Tang.
Old Dec 26, 2011 | 06:39 PM
Dieseljunkie's Avatar
Personally, I am a fan of custom splice...
Old Jan 6, 2013 | 09:24 PM
totalloser's Avatar
Safer and more user friendly? NO it is NOT.
Rope is EXTREMELY susceptible to abrasion when under tension. Which means failure prone. If handled carefully it is fine, but if not handled carefully it is a hazard due to being fragile. One other detail to consider is that most fibers used in winch ropes degrade in strength over time regardless of care.
And to stop the nonsense before it starts, I am a certified tech2 rope rescuer. I love rope, but it's a bad choice for a winch unless in a competition vehicle or where saving weight really matters.
Just two days ago my buddy's winch rope failed dropping an excavator back on it's lid. I set it back on it's tracks with my cable winch. He's getting rid of the rope and going back to cable.
Old Jan 20, 2013 | 02:08 PM
D45's Avatar
D45
I've been using this rope for the past year and a half, without ANY issues or problems
I won't EVER go back to cable, but thanks for the info
Old Jan 21, 2013 | 10:16 AM
slacker 24/7's Avatar
x2 ! i've used winches in 4 wheeling for 40 years, i tried the rope but as stated its very prone to abrasion and just being out in the weather on a winch affects it, it actually should be replaced after just a few years and inspected constantly. True it will go to the ground alot quicker than a cable if it breaks, but a winch weight, (coat,blanket,whatever) should always be used on a cable. and the rope is easier to handle, but for safety and reliability, I have also gone back to cable.
Toolslinger
29
Jan 2, 2006 05:46 PM
2500Ram
Oct 18, 2005 12:00 PM
natstayl
Aug 18, 2005 11:12 PM
matthopp
Feb 20, 2004 10:16 AM
