View Poll Results: MODTR-30 WRENCH DAY ....
Multiple Choice Poll. Voters: 13. You may not vote on this poll
Modtr-30 Wrench Day
I could do this Sat or Sun if you wanted. I've never done one before, but those instructions seem pretty easy to follow. Don't see anything I'd be scared of.
Fix?
Nice shooting by the way.
Now what do you mean by that? After our conversation yesterday I'm not sure it could be air since it doesn't continue to do it all the way to redline.
It's probably electrical. Or maybe someone moded the pump allready and it's showing up now.
How about the skateing rink this morning. I has having fun in it last night. Just don't get a 7k truck going to fast or it won't stop forrrrrr eeeeevvvvvveeerrrrr.
I really would think there might be air, I knwo ti doesn't do it till redline but remember I told youw hat might be causing that. I guess we will see.
I hated it this morning, needless to say, I didn't have to drive thank the lord.
Is a head gasket job too much for a wrench day? My truck has been leaking a small amount of coolant for a while now but it started leaking more(about a gallon every 2 or 3 days). It is leaking just under the thermostat housing. I installed a new thermostat and new rubber seals yesterday but it did not fix the leak. Can anyone tell me how much of job this is? I have done some minor engine work on gas engines but not much on diesels. I'm afraid I will probably be sending this one out for repaiers.
A cherry picker helps in lieu of friends crawling up into the engine bay. Pull the rocker boxes, remove rockers and blocks and pull then push rods. Remove intake horn and unhook heater grids, disconnect exhaust down pipe and IC pipe to turbo and pull the bolt holding the alternator bracket to the head. Unhook pyro, temp gauge sensor, oil line for turbo, boost gauge, NOS, water/meth, etc... Pull all the injectors, return and supply injection lines, remove bolts holding the fuel filter canister to the top of the intake and then head bolts and POP goes the head.
...I've done it a couple of times...re-assemble reverse of removal.
No on the Cp3 but the valves are no biggie the truck really needs to set awhile and be cooled down(really overnite) should take less than an hour to do.
Valves
GS you'r welcome to help after I let it set all night I don't have that much burn cream around anymore.
