Mitusa Install
Old Aug 14, 2009 | 08:30 PM
Doj Dewd's Avatar
Mitusa Install
Well I finally bit the bullet and ordered a Mitusa kit from Opie. Just sent the MO to him today, so I probably won't see it for at least 2-3 weeks as it is coming via regular ground mail.
I don't know when I will be installing it yet, but I know some others were interested in seeing it. So - if interested, you're more than welcome to drop by whenever I do the install to take a look.
Sounds like it is a fairly simple install from what I gathered in talking to Opie. I think the hardest part is going to be plumbing and running the lines. I'm also installing a Perma Cool filter/filter head at the same time so I'm going to have to find a spot for that . . .
On a side note - I won't be going to the AAG Blackout - gotta' work instead!!!
Old Aug 14, 2009 | 08:58 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
I don't know what it is, but it sounds interesting......Must be some sort of 24V thing...
Old Aug 14, 2009 | 09:51 PM
Doj Dewd's Avatar
the Mitusa is a mechanical lift pump designed to replace the stock electric LP's.
It is mounted at the front/bottom of the block and is run by a pulley bolted to the harmonic balancer. as engine rpm's rise - the pumps output rises with it!
Old Aug 18, 2009 | 11:45 AM
Mike Holmen's Avatar
The Guru
You gonna do the draw straw mod? The stock in-tank fuel pick-up system isn't that great. You can gain pressure by just installing a 1/2 pick-up. I have one on the shelf at home, but I haven't had time to install it. It has a nice AN8 or 10 (I'm guessing) so you can tie it to your pump and get a nice tight seal. The return line goes back into the stock drain. Fass users can use the stock connection, instead of teeing the tank breather line. So you can fuel when the truck is running.
Old Aug 18, 2009 | 12:37 PM
Doj Dewd's Avatar
i'm not sure yet - we'll see what all the kit ships with from opie . . .
Old Aug 19, 2009 | 02:56 AM
OPIE's Avatar
I know Opie will not be sending any sort of draw straw. The OEM in tank pick up system is by far superior for a mechanical pump system.
Old Aug 19, 2009 | 08:09 AM
The Guru
Opie, so whats the difference? What type of pump you using? You using the stock fuel lines with your set-up? If you have a hi volume electric pump (not stock) vs yours system, the only difference is that your is mechanically driven. Whats the maximum pressure available at that the injection pump?
Old Aug 19, 2009 | 07:48 PM
OPIE's Avatar
Spur Gear
No Parker pushloc lines that are rated at 300 psi.
If you say so. lol
The small pump max pressure is 100psi the next size up Gusher is 200 and change. But they are both regulated at 16 psi unless requested otherwise.
Hope the above answered your questions
Old Aug 19, 2009 | 09:55 PM
The Guru
Thanks buddy. Good info, I didn't know. I forgot about the rpm increases the fuel pressure. I had a brain fade moment.
Old Sep 5, 2009 | 02:00 AM
Doj Dewd's Avatar
the mitusa kit came in the mail today!!!
i can't wait to get started and put this thing in!
what a well engineered design, and well put together kit. it looks as though EVERY little detail/component was well thought out and NOT cheaped out on!
i'm hoping to get started this weekend or during the week sometime if i'm able to find some time!!
this thing is gonna' be sweet!
Old Sep 5, 2009 | 12:27 PM
morkable's Avatar
Hey Doj,, how much did it cost by the time it showed up to your door? Which model did you go with?
Old Sep 5, 2009 | 03:00 PM
Doj Dewd's Avatar
pm sent regarding price (cheaper than the airdog on sale!!!)
i got the regular pump. there is a larger 'gusher' available and you would probably need the gusher. i don't know how much the gusher is though.
it seems to be a very well put together kit. it is a pump with lines/fittings only. there are no filters in the kit. just have to buy a spin-on filter head and a filter then just plumb it inline on the positive side of the pump.
Old Sep 5, 2009 | 03:41 PM
Dr. Evil's Avatar
SO the opie pump doesnt come with filter and water seperator?
Old Sep 5, 2009 | 03:51 PM
Doj Dewd's Avatar
Originally Posted by Dr. Evil
SO the opie pump doesn't come with filter and water separator?
that is correct. you can get a filter head from napa for $26 CDN and then your 2 micron filter of choice . . .
you can buy 2 filter heads and add a water separator too . . .
i bought a permacool kit from summit racing for just under $40 USD and it includes a head with a 2micron filter/water sep in one canister . . .
Old Sep 5, 2009 | 04:37 PM
Tate's Avatar
Or just run the factory fuel filter canister.
