Mitusa Install
Old Sep 9, 2009 | 07:22 AM
  #31
Doj Dewd's Avatar
Originally Posted by CamperAndy
To stop it from siphoning use shop air, regulated down to 10 or 15 psi to blow the fuel back into the tank.
i don't have that option in the spot i am doing the install . . .
Old Sep 9, 2009 | 08:34 AM
  #32
CamperAndy's Avatar
Then use a shop vac on the fuel tank fill opening.
Old Sep 9, 2009 | 08:40 AM
  #33
Mike Holmen's Avatar
The Guru
I would keep the line off the old lift pump up as high as you can get and leave it on inside the engine compartment. Put a pan under the truck. Try to keep the lift pump suction fitting on as long as you can. The fuel filter will be full of fuel as well. Its only diesel anyways. You'll lose some fuel, but it should stop.
Old Sep 9, 2009 | 09:39 AM
  #34
OPIE's Avatar
You should probably just disconnect the supply line at the tank fuel basket. If it is stock it is a quick disconnect fitting that requires you to push in and squeeze the side tabs to release on top of the fuel tank. You just lean over the drivers side rear wheel and you will see it. However, if it was stock it should not do what you are describing.
Old Sep 9, 2009 | 09:52 PM
  #35
Doj Dewd's Avatar
well i got back at it again today for a short while. i took off the vice grips and cut the soft line from the hard line and no more flow of diesel! for whatever reason it stopped pouring out. must have stopped the siphon effect by clamping the line for a bit.
i'll have to finish up tomorrow as i was short by about 13 feet of hose (2 micron filter mounted underneath and at the front of the bed just in front of the rear wheel well). once i pick up some more push on hose it should be smooth sailing from there on in.
the regulator was mounted, but i found i was unable to align and tighten the fittings properly with it mounted, so i had to pull it off and tighten everything down. that will be re-mounted tomorrow, then i'll just have to finish the plumbing, prime the system, then hopefully she'll fire up without too much difficulty.
anyone know where i can get parker push lock hose in calgary? do i have to stick with parker hose - or will any push on, diesel rated hose be the same as the next?
Old Sep 9, 2009 | 09:54 PM
  #36
Doj Dewd's Avatar
pictures are still being taken, i'll have to find some time once done to downsize and post them up!
Old Sep 9, 2009 | 10:01 PM
  #37
morkable's Avatar
I find it easiest to upload them to photobucket and then post the link,, easy peasy
Old Sep 9, 2009 | 10:31 PM
  #38
Doj Dewd's Avatar
just made an account - stay tuned. i might start to upload tonite!
Old Sep 10, 2009 | 12:20 AM
  #39
Doj Dewd's Avatar
Link to ongoing MITUSA album (Pics, Pics, Pics)
Old Sep 10, 2009 | 12:42 AM
  #40
morkable's Avatar
by looking at your pics, I see a new problem,, I have a fluid dampner,, way bigger than the stock dampner,, do you think that would be a problem?
Old Sep 10, 2009 | 12:48 AM
  #41
Doj Dewd's Avatar
I know the GDP system (knock-off of Opie's Mitusa) will not work with an aftermarket balancer.
I think i heard somewhere that Opie may have had a solution for this. I'm not sure, so I can't say.
Also - you have dual CP3's. I know Opie has a kit for your application and I believe the pump is mounted up in the engine bay as opposed to below it.
I'm sure he will chime in here . . .
Old Sep 10, 2009 | 12:59 AM
  #42
morkable's Avatar
cool
Old Sep 10, 2009 | 01:40 AM
  #43
Dr. Evil's Avatar
Good pics Jason.
Can you get this with 1/2" line instead of the 3/8"??
Old Sep 10, 2009 | 08:05 AM
  #44
The Guru
Jason, are you putting the 2 micron filter on the suction side of the pump?
Old Sep 10, 2009 | 11:08 AM
  #45
Doj Dewd's Avatar
dr. evil - i don't know if Opie will ship them with 1/2, but it looks like it could be done. just have to get the fittings for 1/2 instead of 3/8 as well as the hose. i only see one problem in doing this - the stock supply line from the tank is 3/8 OD so you would have to adapt somehow or run a whole new supply line.
i asked Opie about running 1/2 line and he just kinda chuckled and said no, no 3/8 will be more than enough! the kit i ordered comes with 3/8 line. he has bigger pump kits - maybe they come with 1/2. i couldn't tell you for sure though.
mike - the 2 micron filter is on the positive side of the pump, not the suction. although Opie said i could run it on the suction side, it would just be more difficult for it to prime, but once primed he said it really doesn't care what you throw at it.
