In Search of 5" - 6" suspension lift kit
Old Jun 12, 2011 | 12:26 PM
lukedaemon's Avatar
I am in the market for a 5 - 6" suspension lift. I have spotted a few, but I have never purchased a lift kit before. I am not a heavy off-road user. I want to run 35's and my wheels with zero rub. A 2" leveling kit failed.
This one is the one I am leaning towards...
Rough Country Dodge Lift Kits
2003-2007 4wd Ram 2500/3500 / Mega Cab 5" Series II Suspension
Kit Contents:
Heavy duty, tubular, upper and lower control arms, lifted front coils, pitman arm, sway bar links, track bar relocation bracket, (4) RC Hydro 8000 series shocks, u-bolts, and option of 3" or 4" rear blocks.
Description:
The upper and lower arms are longer than stock to rotate the axle for proper alignment, as well as greasable for long term performance. The drop pitman arm maintains the factory steering angles and the track bar relocation bracket properly centers the axle under the vehicle.
Notes:
• Does NOT fit dually models.
• Must know if rear axle is 3.5" or 4" wide.
Benefits:
• 100% bolt-on installation.
• Increased ground clearance.
• Maintains factory steering angles.
Specs:
• Install Time: 4 - 6 hours
• Wheel Backspacing: Factory
• Recommended Tire Size: 37x12.50
Priced at: $770
Old Jun 13, 2011 | 05:09 AM
scottsjeeprolet's Avatar
I'll help you put it on when you get it Rick.
You might want to copy this and post it over in the 3rd gen performance section for more exposure.
Old Jun 13, 2011 | 01:03 PM
lukedaemon's Avatar
Thanks I am sure I will need the help.
The Rough Country set up looks pretty good for me. I have to figure out which size axle I have. It is asking for options 3.5" or 4" axle sizes. I have the heavy duty package on my truck.
Old Jun 13, 2011 | 04:27 PM
06 DIESEL's Avatar
4" iirc
Old Jun 13, 2011 | 05:56 PM
b4wheeler's Avatar
http://www.pirate4x4.com/forum/showthread.php?t=983946
lukedaemon
Apr 3, 2018 09:24 AM
steelblitzkrieg
Aug 18, 2011 08:06 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
whitetrash66
26
Sep 13, 2007 09:57 PM
trik396
Aug 4, 2006 01:58 PM
