lost keyway VP44
Old Mar 12, 2009 | 12:25 AM
BlackRam1's Avatar
lost keyway VP44
I lost the key for my new pump need help what now???
write back call me need help 928-713-0021.
Frank
Old Mar 12, 2009 | 07:27 AM
patdaly's Avatar
You have to get the key that is correct for your pump, not sure where on the pump the number is located ( cant remember if it is on the shaft or the body ), but it is critical to have the number on the key match the pump for timing.
Probably going to have to get it from a Bosch pump dealer.
Old Mar 12, 2009 | 11:55 AM
kthiemann's Avatar
As said above you have to have the right key for the pump. If memory serves the key number is printed on the pump label, and may also be stamped on the pump near the mounting flange.
Old Mar 12, 2009 | 11:40 PM
granahan378's Avatar
The key number is stamped on the pump, i mushroomed mine when i installed it, any local bosh dealer should have it they will give you the bs line of it wont work and needs to be recalibrated blah blah blah it works just fine as long as its the same key, 45k miles later and still kicking.
ClassA4x4
Apr 11, 2013 09:36 AM
guhfluh
Oct 23, 2006 08:13 AM
TNutcher
Aug 25, 2006 12:26 AM
baffled
May 4, 2006 11:02 PM
txbubba
Aug 24, 2005 09:07 PM
