noob with Dodge pickup
Old Aug 22, 2008 | 05:14 PM
kell's Avatar
Bought a 2500 (1994 with the Cummins engine).
Old Aug 22, 2008 | 05:51 PM
MCummings's Avatar
That'd be a 160HP motor and I THINK 460TQ stock.
What trans? Body? Miles?
Merrick
Old Aug 22, 2008 | 06:00 PM
kell's Avatar
I got the build sheet from Chrysler:
Light Group
Heavy Duty Service Group
Heavy Duty Insulation Group
Convenience Group
Monotone Paint
120 Amp Alternator
750 Amp Maintenance Free Battery
Pwr Disc/Drum Rr Anti-Lock Brakes
Rear Drum Brakes
40/20/40 Split Bench Seat
Driver Air Bag Only
Deluxe Headliner
Front Seat Area Carpet
Passenger Assist Handles
Mini Overhead Console
Behind Seat Modular Storage System
Storage Tray
All 4-Speed Automatic Transmissions
4-Speed Auto 47RH Transmission
Lock-Up Torque Converter
Shift-on-the-Fly, 241 Transfer Case
Dana M60/248MM Front Axle
4.10 Axle Ratio
Dana M70/267MM Rear Axle
5.9L I6 Cummins Turbo Diesel Engine
Tinted Glass Windows
Tinted Windshield Glass
Front Door Tinted Glass
Rear Sliding Window
Rear View Day/Night Mirror
Manual 6 x 9 Black Mirrors
All Vehicles W/O Power Mirrors
Heater
Hood Insulation
Dash Liner Insulation
Deluxe Insulation Group
Instrument Cluster w/Tach
120 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Cigar Lighter
Single Low Note Horn
12V Auxiliary Power Outlet
STRIPE/BADGE/MOLDING
Ignition Time Delay Lamp
Map/Courtesy Lamp
Glove Box Lamp
Underhood Lamp
Halogen Headlamps
Clearance Lamps
Cargo Lamp
Bright Rear Bumper
Bright Front Bumper
Front License Plate Bracket
Bright Grille
Black Windshield Moldings
Journey Badge
Removable Tailgate w/Caliper Latches
Front Air Dam
Delete EVAP Control System
35 Gallon Fuel Tank
Auxiliary Transmission Oil Cooler
Engine Block Heater
Speed Control
Heavy Duty Engine Cooling
Diesel Emissions
Black Clear Coat
Black Clear Coat
All Radio Equipped Vehicles
AM/FM Radio
2 Speakers
Power Rack and Pinion Steering
2-Spoke Steering Wheel
Front Heavy Duty Shock Absorbers
Rear Heavy Duty Shock Absorbers
Front Stabilizer Bar
Tilt Steering Column
Full Size Spare Tire
Tire Carrier Winch
LT245/75R16E BSW All Terrain Tires
Goodyear Brand Tires
16X6.5 Steel Wheels
All Steel Wheels
Black Hub Caps
Bright Wheel Trim Rings
Pickup Box
Transfer Case Skid Plate Shield
Build To U S Market Specifications
10 Additional Gallons of Diesel Fuel
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
The previous owner let this truck sit in his yard for two years unattended. Said he tried to start it last year but couldn't; I can't start it either (lots of bleeding, cranking).
Can't go look at the truck right now but it has less than 200k I think.
Old Aug 22, 2008 | 06:36 PM
MCummings's Avatar
Make sure the shut down solenoid is pulling up all the way...
Merrick
Old Aug 25, 2008 | 06:36 PM
kell's Avatar
Thanks for the tip. The fuel solenoid linkage got froze up with rust from sitting outside for such a long time. Freed it up and the truck starts.
I have a couple of other things I need to fix before I can actually drive the truck. I posted a question in the 2nd generation forum about an electrical problem.
BRUISER
Dec 7, 2006 08:44 PM
theextricator
Aug 1, 2005 10:47 PM
Commatoze
Feb 5, 2004 10:50 PM
sdscuba
Feb 21, 2003 08:26 PM
