Another new guy from PA
Old Jul 6, 2008 | 09:32 PM
MikeBrei's Avatar
I just bought my first diesel and I'm lovin it. I always liked the G2 rams and I found one last week that was a one owner and only had 32000 on it and it cherry inside and out. Its a 2001 ext cab SB camper option with 4:10 gears. I already ordered a S&B intake kit for it and I was looking into an MBRP exhaust and a Superchips MAX MicroTuner. I wanted to see if there is anything else I should look into before I buy the exhaust and the tuner. I also wanted to know if anyone has tried this exhaust system before. Thanks
Old Jul 6, 2008 | 11:11 PM
madhat's Avatar
Administrator/Jarhead
Welcome to the DTR.
I have used MBRP before, it's pretty good. I have a silverline now and like it too.
Guages!! You need them before you start heavy bombing!
Old Jul 6, 2008 | 11:55 PM
Jason_K's Avatar
you definitely need guages before you get a power adder, and in my opinion there are better power adders out there than superchips. do a search on the subject and you'll find a ton of info. where in pa are you from?
Old Jul 7, 2008 | 02:07 PM
John_P's Avatar
Mike:
Welcome to the website!
John_P
Old Jul 7, 2008 | 03:12 PM
MikeBrei's Avatar
Thanks for the invite guys!
Not to sound to NEW here but which guages should I get for it? I will do some roaming on here and find some things out. I picked out the superchips because I just want to change the shift points and I don't want to do too much to it right now.
I'm from around Pottstown PA.
Old Jul 7, 2008 | 03:22 PM
Howdy neighbor! I'm just down the road from you.
Fuel pressure gauge is a must on a 24 valve truck. Also get a pyrometer, boost gauge, and a trans temp gauge (if it's an auto).
Old Jul 8, 2008 | 12:51 AM
Jason_K's Avatar
x2 with what he said. once you start throwing some power at it, i'm sure an aftermarket lift pump will be in your not too distant future. when i had my 01, i hooked up and edge juice w/ attitude and saw that my Fuel pressure was dropping to 0 under moderate throttle. Bought myself a FASS and never had another problem. At least until i hit that huge telephone pole
HMX-1
Introductions / New People
Sep 19, 2009 08:24 PM
slothrockit
Jul 5, 2008 10:25 AM
Ls1z28fbody
Nov 27, 2006 08:03 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
aar_man
16
Jun 28, 2005 09:50 AM
