Won't Start
Old Sep 2, 2008 | 02:48 PM
uber_dzl's Avatar
Unhappy Won't Start
I disconnected the baterries for about 30min and when I reconnected them, the truck wont start. It cranks so the batteries arent dead or anything.
When I connect the smarty, it gives me an error code(#112 Wrong communication). Not an engine trouble code.
Please help I have class in an hour.
Thanks
Old Sep 2, 2008 | 02:54 PM
P.J's Avatar
P.J
Connected back up good, right? Grounds good?
Old Sep 2, 2008 | 02:58 PM
uber_dzl's Avatar
everything is connected correctly
Old Sep 2, 2008 | 02:59 PM
P.J's Avatar
P.J
Sounds ECM related.
What was your reason for having it disconnected?
Old Sep 2, 2008 | 03:00 PM
uber_dzl's Avatar
installing a subwoofer amplifier
Old Sep 2, 2008 | 03:01 PM
uber_dzl's Avatar
I had the same amplifier on before but had disconnected it for two months and was reconnecting it today.
Old Sep 2, 2008 | 03:07 PM
P.J's Avatar
P.J
Error Code 112 - Communication Failure Between Display ECU (795) and Engine ECU
Old Sep 2, 2008 | 03:09 PM
uber_dzl's Avatar
What do I have to do to fix it?
Old Sep 2, 2008 | 03:11 PM
P.J's Avatar
P.J
Hang on, I'm searching and thinking.
Common sense (and retarded personal experience) is telling me that you have something unhooked or have blown a main fuse in the engine bay.
Take a quick look at some of your fuses, only takes a minute or two to pull them.
Old Sep 2, 2008 | 03:14 PM
uber_dzl's Avatar
I was just gonna run out and check the fuses, thanks for the help. I will be right back.
Old Sep 2, 2008 | 03:19 PM
06RAM2500's Avatar
I've got access to a service manual, just in case!!
Old Sep 2, 2008 | 03:28 PM
06RAM2500's Avatar
Double check the IOD fuse.
Old Sep 2, 2008 | 03:29 PM
P.J's Avatar
P.J
Well, you're late for class,................ what's the word?
uber_dzl's Avatar
I just checked all the fuses in the box and they were all fine, I replaced the Ign switch fuse with a new one just in case.
What is the IOD fuse?
Old Sep 2, 2008 | 03:30 PM
06RAM2500's Avatar
Fuse #27 IOD #1 40A green or #28 IOD #2 (audio) 10A red
