wireing
Old Mar 16, 2003 | 11:11 AM
bishgeo's Avatar
wireing
Trying to tie into marker light wires at front of truck for extra lights.Any body know what color wire to tap with out me trying them all.The harness i found has about 6-8 diffrent color wires in it. Thanks
Old Mar 16, 2003 | 11:22 AM
FEAC's Avatar
Re:wireing
What color are the wires and how many.<br>Thank you<br>Adam<br>
Old Mar 16, 2003 | 11:51 AM
bishgeo's Avatar
Re:wireing
8-10 wires<br>white<br>green/purple stipe<br>purple/white stripe<br>white/blue stripe<br>purple/red stripe<br>brown<br>red<br>red/purple stripe<br>blue<br>two grey<br>black
Old Mar 16, 2003 | 02:03 PM
Stamey's Avatar
Re:wireing
My Haynes manual has the color for marker lights as being Yellow all the way through. The turn signal wire is black, then turns tan just before it gets to the light. <br>And the ground is black.<br>Perhaps you have not found the correct harness.<br><br>Chris
Old Mar 16, 2003 | 04:32 PM
Jrr's Avatar
Jrr
Re:wireing
I personaly dont like tapping into the original harness to add lights. My recomendation would be to use a 12v relay and use marker light for the trigger. Then go directly from battery with a fuse to your additional lights alot safer than overloading the stock harness the marker light circuit is a week link on these trucks.
Old Mar 16, 2003 | 07:19 PM
bishgeo's Avatar
Re:wireing
Marker light wire turned out to be black with a yellow stripe.
Old Mar 18, 2003 | 07:52 AM
P Kennedy's Avatar
Re:wireing
bishgeo I agree with the other post use factory light feed as relay trigger only as the wiring in these trucks is too light already. Just wired 17 LED's into new deck that draw .03 amps less than factory &quot;2&quot; tail light bulbs and headlight switch stays cooler. Also these trucks have the computor integrated into the wiring and sometimes picks up voltage drop in light feeds and will cause head aches. PK
hwp
Mar 13, 2005 08:56 PM
dodgeman01
Aug 16, 2004 09:30 AM
wgingg
Jun 4, 2004 11:52 PM
joshfj40
Jan 26, 2004 09:44 AM
boughtadodge
Dec 18, 2002 09:57 PM
