will this tranny fit
Old Sep 24, 2003 | 09:02 PM
rackshakermac's Avatar
will a 47re out of a 2001 4x4 2500 fit in my 96 2wheel dr 2500 ct diesel ???
Old Sep 24, 2003 | 10:26 PM
tmiller24's Avatar
Re:will this tranny fit
Sure, it will bolt right up to the back of the engine,BUT you would need to use your OD unit and I'm not sure how to make it work once you do all that. I mean that the fluid pressure control is all electronic, hence the E in RE. What you may consider is taking the parts out of the RE and put in your RH. Most of it will interchange. Good luck!
Old Sep 24, 2003 | 10:46 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
The 96 truck uses the RE tranny.
Old Sep 24, 2003 | 11:17 PM
tmiller24's Avatar
Oops! :-[ In that case pull off the OD units, change all the good pieces into the 2wd tailhousing and swap'em out. Output shaft lengths are different I think, but all the clutches are the same I believe.
Old Sep 24, 2003 | 11:36 PM
is it the solenoids you are speaking of or what exactly when you say the "overdrive units"? thanks guys
Old Oct 5, 2003 | 08:35 PM
Den052's Avatar
What we call the "overdrive" unit is basically the tail section. The part that unbolts from the main case. It has about 6-7 bolts. The 4wd unit and the 2wd unit are different. The main case of the transmission is the same.
To remove the tail housings, you have to unbolt a small cover (2 small bolts) that has a big snap ring inside. Then you unbolt the rear housing and while spreading the snapring, you pull back on the housing. Once it comes apart, the meaning is clear on the purpose of the snap ring.
Black Dog
Dec 3, 2009 08:18 PM
tfdcruiser
Apr 23, 2007 08:39 PM
fordsux8269
Jul 21, 2006 07:20 AM
edge600
Mar 12, 2006 10:15 PM
