whistling intake
Old Jan 3, 2006 | 05:34 PM
rnstruck's Avatar
Exclamation whistling intake
I need help and by the looks of it I found the place to get it. I just traded my 97 v10 in and got my first diesel 2001 2500 short bed a/t I am in heaven. BUTTT I put a k&n in a few weeks ago and now I am hearing a very high pitch whistle could it be the filter. am wondering this after reading your ideas about k&n. While writing this I just ordered a napa 2790 bhaf.
Old Jan 3, 2006 | 05:38 PM
Herrin811's Avatar
That is the lovely sound of turbo power
The k+n probably helps it get louder than stock, but its normal
you'll learn to love it
Wait till you hear that BHAF suck like a shop vac!!!
Old Jan 3, 2006 | 05:39 PM
Racer9's Avatar
It's probably just the turbo. Do you hear it mostly when the motor is working? After the bhaf you'll hear it even better. Most of us enjoy it so much we remove the silencer ring, so we can hear it better.
Old Jan 3, 2006 | 05:40 PM
Racer9's Avatar
Dang Herrin, you beat me by a minute!
Old Jan 3, 2006 | 05:54 PM
rnstruck's Avatar
Question whistle
Sorry guys for got to type in its not the wonderful sound of the turbo. It is an annoying whistle very loud and only evident during mild acceleration. when getting on it the turbo over powers the whistle. thanks
Old Jan 3, 2006 | 06:01 PM
rnstruck's Avatar
racer9 new at all this so dont know if you will get my new ques I posted. anyway its not the turbo and its only under a constant or mild acceleration.
Old Jan 3, 2006 | 06:14 PM
crobtex's Avatar
There is restrictor valve on one of the heater hose lines that will cause this. On my '99, it's located on the passenger side of the engine, toward the back, up near the valve cover. If you look at this pic, you can see it coming out of the firewall to the engine. The one on the right.
Old Jan 5, 2006 | 03:28 PM
redhauler's Avatar
you could always add an Amp to the stereo and crank it up!
that should lessen the turbo but AHHHHH the sound of power.
Old Jan 5, 2006 | 03:58 PM
ratsun's Avatar
Sounds simple but are you sure the air box is sealed up right?
Old Jan 13, 2006 | 09:22 AM
abb's Avatar
abb
Red face this might help?
Ok you don't think it's your turbo did it whistle before you changed filthers? I put a cold air pack on mine, before quiet afther wow what a whistle now I did put the torque tube on it. Any way it was really loud so put a turbo air guide, {TAG} on it now this product is for making the turbo get a better bite because it stops the swirling of the air another thing it does is quietens the whistle not all of it but enough to live with, cost about 120.00 I'm on my 2nd trk with the same system and both whistled.
Old Jan 13, 2006 | 06:53 PM
handymantim's Avatar
Take the air filter out and drive it around the block for a test.
Old Jan 14, 2006 | 07:56 AM
berner's Avatar
I seem to remember reading that K&N's don't seal very well in the airbox sometimes. Some guys have used a bit of grease on the sealing surfaces. Are you sure you don't have a small boost leak? Check for a cracked intercooler boot and make sure all the clamps are tight. They should be torqued to 72 in-lbs.
Old Jan 17, 2006 | 09:20 PM
lil smokey's Avatar
k&ns are not good for the motor. a friend had a drop in k&n in his 99 ctd. after a while, he had to get some motor work done. they said the cylender walls looked like someone had sandblasted them. not good
CDoskocil9
30
Dec 12, 2006 10:29 PM
piperca
Feb 1, 2005 08:50 AM
PCarnathan
Dec 7, 2004 10:52 AM
DrBob
Jun 2, 2004 12:10 PM
Slice
Mar 16, 2004 09:13 PM
