Wheels Spacers????
Old Jun 14, 2007 | 05:53 PM
Adam3291's Avatar
Wheels Spacers????
I'm currently in the middle of rotating the tires on my truck. I have never noticed it before but my passenger side front wheel has a spacer on it and the drivers side does not. Do I need this spacer for any reason on that side cause if not I'm going to take it off. I will come back and check this thread before I finish up. Any help would be appreciated. Thanks
Old Jun 14, 2007 | 05:56 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
spacer????????????? did these trucks come with them? I don't think so.
Old Jun 14, 2007 | 05:57 PM
Adam3291's Avatar
Yeah, it has a spacer on the passenger side that says RH only.
Old Jun 14, 2007 | 06:06 PM
Box5's Avatar
how thick? and does it offset the wheel when u look at the front of the truck or does each wheel look uniform?
Old Jun 14, 2007 | 06:10 PM
moparmikej's Avatar
I think I read somewhere that the spacer corrects a slight pull to one side under hard braking. Mike
Old Jun 14, 2007 | 06:14 PM
JPR Ram's Avatar
hmmmmmmmm. I know up to '99 the the rotor's and the bearing unit where pressed together, and that '00 and newer the rotor's will just sit on the bearing unit. But I've never seen a spacer. We just did the brakes on our '99service truck and I just did my brakes yesterday........no spacers.
Old Jun 14, 2007 | 06:16 PM
Adam3291's Avatar
I think I'm going to pull this spacer off and see what happens. Worst case I have to put it back on. I would probably say the spacer is about an 1/8 thick or so. That is just rougly guessing.
And to answer the question early, yes if you look hard at it you can tell its offset.
I also want to note that I have always had excessive wear out of the passenger side tire.
Old Jun 14, 2007 | 06:36 PM
Shovelhead's Avatar
Administrator / Scooter Bum
This was the Coprorate "FIX" for the "Pulling to one side when braking" problem that many early 2nd genners experienced.
Spacing one wheel out slightly changed the leverage "correcting" the problem.
Old Jun 14, 2007 | 06:52 PM
Adam3291's Avatar
Well I know one thing, my truck pulls to the right with it on so it has been taken off. Fixing to go change the air pressures and do a test drive and I will let u guys know what I come up with.
Old Jun 14, 2007 | 07:00 PM
infidel's Avatar
The spacers were a bandaid fix that came in three thickness and didn't work. Many times they get transfered to the wrong wheel in a tire rotation. All the people I've known of who have removed the spacer have noticed absolutely no difference.
Old Jun 14, 2007 | 07:25 PM
Adam3291's Avatar
Well they are needed on mine. you only notice it when braking real hard. I just put it back on.
Thanks for all the help and information guys.
Old Jun 22, 2007 | 02:27 PM
high bid's Avatar
Yes, my 99 had the spacer on the right front as well. When changing a blowout, I noticed it and was wondering the samething. Threw it in the back of the truck and haven't noticed any difference.
tontof18
Sep 28, 2006 07:59 PM
Dave88LX
Jul 13, 2005 08:34 AM
Gary C
27
Mar 11, 2004 07:42 PM
