welding downpipe
Old Jun 26, 2005 | 12:20 PM
Evildiesel's Avatar
welding downpipe
I pulled the old post turbo egt probe in my '02 and am preparing to mount a new one in the manifold. I need to fill in the hole where the old probe was. Is the heavy piece right behind the turbo steel or cast iron? I only have steel wire and can't weld in to cast. Suggestions?
Old Jun 26, 2005 | 12:44 PM
Junk Yard Dog's Avatar
Just run a pipe plug into the existing hole you don't want to use
Rick
Old Jun 26, 2005 | 12:45 PM
sherod's Avatar
Why not just put a pipe plug into it? That way, if you need it in the future, you still have it.
Don't know the answer for sure on cast/steel.
Ed
Old Jun 26, 2005 | 01:09 PM
It's cast iron. Like the first 2 guys said, just put a pipe plug in it, no need to break out the welding rod.
Old Jun 26, 2005 | 02:03 PM
Evildiesel's Avatar
I didnt put a pipe plug on because the guy that did it used a band clamp type install and the hole is unthreaded, I dont think I have any taps either.
Old Jun 26, 2005 | 02:35 PM
Evildiesel's Avatar
Nevermind, found my taps...ran it through....Thanks!
97catintenn
Jul 12, 2009 05:33 PM
JimmieD
Aug 22, 2006 10:47 PM
CTD99
Aug 6, 2003 06:36 AM
vaquero
Jul 16, 2003 08:55 PM
rattle_rattle
Nov 18, 2002 05:12 PM
