Water pump leak
Old Oct 8, 2002 | 05:56 AM
shortround's Avatar
From: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
Water pump leak
Doing a head scratch on this one.<br>My son has a 98 Dakota w/3.9. Replaced the water pump a couple of months ago and found out the pump wasn't bad, just leaking at the bottom of the pump housing/block mating surface. It would appear to be doing the same thing again. It leaks only at an idle or just after shutting the engine off.<br>The surfaces were cleaned and a thin coating of rtv placed on both surfaces. I did notice that the gasket material was very thin as compared to other water pump gaskets.<br>It may be nothing more than a bad/poorly designed gasket. Has anyone experienced this problem before? If so, what did you do to correct it?<br><br>Bruce
d zul
Jul 19, 2010 09:02 PM
ted_pulliam
Oct 15, 2009 08:24 AM
rootremblay
Mar 8, 2009 04:41 PM
oberon1974
Jul 9, 2007 08:53 PM
RamWheelsBy4
Apr 11, 2007 04:43 PM
