Water Leak
Old Apr 11, 2008 | 06:38 AM
Redliner's Avatar
Water Leak
My truck is leaking antifreeze from somewhere at passenger front corner of motor. Water pump looks dry, all hoses over there look good.... Its really wet behind the A/C compressor. I got a 55 block. ANY IDEAS??????
Old Apr 11, 2008 | 09:57 AM
kthiemann's Avatar
Best bet is to pressure test it but if the hoses are all good and water pump is good I would want to take a real hard look at the oil cooler gaskets and the freezeplugs. Another possibility is mebbe the head gasket is leaking and running down the side of the block.
Old Apr 11, 2008 | 11:06 AM
Redliner's Avatar
I found it thanks. Its the water pump. The weep hole is in a different place than any other pump ive seen. It actually is between the pump housing and block face. Thanks though...
D2 Cat
Jul 5, 2007 09:47 AM
LightningMqueen
Apr 24, 2007 08:57 PM
RamWheelsBy4
Apr 11, 2007 04:43 PM
kev211
14
Feb 22, 2007 03:39 PM
Gene Peterson
Jan 7, 2006 02:32 PM
