valve body ???
what is the trick to instaling the valve body the rod that faces the rear of the truck will not go far enghuff back for the valve body to fit properly im asumeing that the hole that the rod sits in is small and not taperd and i missing it let me know what u all know
That helps, and it is a little off from where you think it is. I wrap front end of shaft with length of wire and use screwdriver to guide into shaft. Use feeler gauge the hold spring and accumulator in place while installing VB. Use a pan bolt to hold feeler gauge in place. With wire and screwdriver can get rod into lever. A pair of needle nose pliers holding clip will help. Tie a piece of thread on E clip, so when you drop you can find.
Trooperthorn
Jan 7, 2011 12:55 AM
12ValverDave
Nov 15, 2008 03:50 PM
