Steering help for 98 2500 HD (can't remember which way parts go)
Old Feb 29, 2008 | 06:19 PM
Purplezr2's Avatar
See the diagram and question that go with each, my damned CRS I can't remember how I took it apart
1. Pitman arm, does it nut sit on top of the pitman arm facing the engine, or on the bottom facing the ground
2. Draglink to crossover connection, nut on the rear or the front
3. Steering knuckles, nut on top or bottem.
Insight would be appreciated
Old Feb 29, 2008 | 06:33 PM
J Lent's Avatar
The pitman arm goes onto the steering gear shaft then the washer, then the nut.[nut toward the ground] The drag link attaches to the tie rod by pushing it through from the rear & the nut goes on the front side toward the front of the truck. Make sure to torque the nuts to spec & install a cotter pin. Make sure that you tighten down the clamps on the center of the drag link, where the 2 bars go together.
Old Feb 29, 2008 | 06:40 PM
Purplezr2's Avatar
what way does the drag link go into the pitman arm and which was does the connecting tie rod go(the long bar from the two steering knuckles)
Old Feb 29, 2008 | 07:02 PM
J Lent's Avatar
I'm trying to find you some pics.
Old Feb 29, 2008 | 07:34 PM
J Lent's Avatar
Here you go. Best I could find.
Attachment 20282
Attachment 20283
Attachment 20284
Attachment 20285
Attachment 20286
Old Feb 29, 2008 | 10:38 PM
JKM's Avatar
JKM
Because of the taper on all of the joints, there is only one way they will go together.
Old Mar 1, 2008 | 06:07 PM
Purplezr2's Avatar
Originally Posted by J Lent
Thanks, but my steering was different then that pictured
Figured that out when I got under the truck.
Thanks
nbaggett89
Dec 26, 2015 09:36 AM
nrussell
Sep 3, 2009 03:13 PM
Duallydog
Nov 22, 2008 11:59 PM
CTD_Neil
Jul 19, 2005 08:13 PM
