valve adjustment
Old Oct 11, 2005 | 08:30 PM
ambrosini's Avatar
valve adjustment
can anyone tell me how?
i have the valve cover off and there is 28 clearance on exh and 15 intake.
is there amethod of adjustment?
Old Oct 12, 2005 | 11:44 AM
rkarr55's Avatar
Valve Lash Adjustment
For instructions, go to the header on this board and Click on "Tech Facts". Go to 2nd Gen 24 valve and then the procedures for adjusting valve lash.
Did this a few weeks ago and never did figure out how to remove the crankcase breather from the front of the engine. Maybe someone else can chime in.
Old Oct 12, 2005 | 03:42 PM
jrs_dodge_diesel's Avatar
Crankcase breather, removal is easy. Take the hose off of it and then twist it off. It screws onto the block. 1 full turn removes it. Behind it you will find the timing mark. The 'hole' you removed the breather from has two indents in it, one at the 12 oclock position and 6 oclock position. 12 is TDC and 6 is BDC. You will need a mirror to be able to see the marks to line them up. Other wise it is an easy procedure. I will be writing a tech article (with pictures) covering this procedure soon.
Old Oct 12, 2005 | 06:43 PM
mhuppertz's Avatar
You can also adjust them by slowly rotating until the exhaust valves start to open (on the particular cylinder you are working in) and adjust the intake tappets. The slowly rotate until the intake valves just finish closing and do the exhaust clearances. I run them three times to make sure I have them right.
Fishbait
Nov 23, 2009 11:21 AM
ConnerCop
May 5, 2009 07:48 AM
dhughe2
13
Dec 6, 2006 07:40 AM
bulthisl
Mar 22, 2003 07:01 AM
blackboat
Nov 8, 2002 06:32 PM
