Vacuum pump seal?
The seal on my vacuum pump has finally bit the dust. Now its become an automatic rustproofing device!!HEHE
I remember someone saying you can get this seal from Genos but for the life of me I cant seemed to find it on his website. Does anyone have a number for this seal as its always a pain in the neck getting things across the border up to here? Last time I bought something the taxes,duty and shipping were more than the product!!
Thanks
Jason
Thanks
Jason
It's in the tech facts............ https://www.dieseltruckresource.com/...n&onlynewfaq=1
Thanks very much guys, i went and did a search on here and found a pile of info. I will order the seal and oring on monday from a local supplier, they had the seals but then I remembered I needed the orings so will get it all at once.
One thing I would like to know from someone who has had one out is if it has a spring inside and is it a double lipped seal or a single.
Thanks
Jason
Thanks
Jason
I did the seal on my 2002. The seal you need is part # 28X38X7AV. This seal is made of Viton. I got it through Kaman Ind. via International Seal & Packing. It has a spring and is double lipped.
http://www.intsealpack.com/
ISP would like to work through a dealer thus my using Kaman. I have seen a part # 10924 from CR, but when I checked into the material that is was made of it was not Viton. If it's butyl rubber it's only good to about 200 degrees. I don't think that's high enough for this application. Viton is rated for 400 degrees.The seal cost me $9.67.
As far as the o-ring I reused mine as I got the wrong one. It isn't leaking anymore. I didn't find out until I had the pump apart. I should have measured it but wasn't thinking. If any one knows the size I would appreciate you letting me know.
Hope this helps, Frank.
Well, my pump is apart on the bench and I too have the wrong size O ring.
I will drive around the country side tomorrow and see if I can find the proper O rings to do the job.
Another thing is there are Two O rings to contend with so when I find out what size they are I will post them here and then one of the moderators or administrators can add the sizes to the thread in the tech facts.
Wish me luck
Jason
Wish me luck
Jason
jimbo486
May 8, 2016 06:07 PM
yomitch
Apr 21, 2003 06:28 PM
