Vacuum pump oil seal
Hi all! I have a slight problem. My 98 12 valve vacuum pump oil seal has sprung a terrible leak. I removed the pump and purchased a new seal but i have not figured out how to replace it. i went to the dealership and got the manual for my truck and it shows a p/s pump adapter that bolts onto the vacuum pump, but mine doesn't have this. All I have is the vacuum pump and p/s pump, and the only way to unbolt the vacuum pump is to take it apart into 2 pieces. it appears that there is a metal sleeve pressed into the back of the vacum pump containing the oil seal and the p/s pump shaft coupler. If anyone has any ideas or has run into this problem before then by all means please help!!! ??? well thats about it if i run into any other problems i will post them. thanks all
Re:Vacuum pump oil seal
I was reading up on this the other day. As I recall, there is an "O" ring between the two. I believe there are 2 nuts (I could be mistaken) that you remove to separate them.
Loren
Loren
ok guys after 4 hrs and a trip to cummins to ask a few questions and pick up some parts i finally figured out this seal delema. i will post a few pics and what to do as soon as i finish reassembling my truck for work on mon. thanks again to all who tryed to help. i hope my upcoming info will save yet another person from being robbed by dodge for a 900 vacuum pump
Just a reminder to any of you out there that have not had an oil leak at the vacuum pump yet, (eventually you will). Replace (or have replaced) BOTH the seal and o-ring. I had to take mine back to Cummins twice before they replaced the o-ring and finally cured the leak.
Re: Re:Vacuum pump oil seal
Thanks, Frank.
Unfortunately, I do not have all the details. I had Cummins do the job so I'm not sure exactly where the o-ring is. They also did not invoice me since they did not charge me for it, so I don't even have a part number for you. Any Cummins dealer should be well aware of this problem and should be able to give you part numbers and maybe make you a copy of a parts breakdown if you ask them. The parts are not available to Dodge, so they probably will not have a parts diagram to give you.
It seems kind of funny that the pump is a DC part but they don't have parts for it, but Cummins does. I will try to get in touch with a Cummins dealer and see if they can help me .
Thanks for your help, Frank.
John Strenkowski at jvssyn@rcn.com sells the seal and oil ring for good price. They're hard to find elsewhere.
Well i hope this helps somebody. i had my vacum pump replaced by dc under warranty. they were going to sell me a reman until i reminded them about the warranty. the seal was bad so they took the pump out and nailed the warranty co for $1354.00. i got to keep the old pump for futue use and got the # for a napa seal.
It ia a 38mm od x 28mm id x 7mm wide double lip viton seal
napa # 10924. i will check with napa some day and see if that really it.
