vaccum pump running all the time
Old Oct 30, 2009 | 06:34 PM
tim2251's Avatar
2004 ram 3500 on the passanger side behind the battery there is a electric vac pump that started running and never shuts off I am sure there must be a leak but what does the pump do what if i just unhook the electrical ??????????
Old Oct 31, 2009 | 08:06 AM
SAVOY1964's Avatar
5.9L Diesel Engines With Automatic Trans.
If equipped with a diesel powered engine and an automatic transmission, an electric vacuum pump and vacuum lines are used to supply vacuum to the speed control servo(cruse control). A vacuum reservoir is not used.
I would follow the lines from there back to the pump you may have a sopt that is worn through.
robert78.5
Apr 3, 2010 10:57 PM
MARSHILL
Apr 30, 2009 01:17 PM
plow
Jun 3, 2005 09:38 AM
signature600
Apr 11, 2005 07:33 AM
JCHMOTOR
Jan 8, 2004 09:56 PM
