Truck won't start Help Please
Old Jan 27, 2006 | 12:31 PM
JTBbudman's Avatar
My truck quit yesterday when i crossed rail road crossing (not a hard bump either) Replaced fuel filter, checked fuses, nothing. All connections look good
truck barely tries to start after minutes of turning over. Used Mac Tools MasterCraft Scanner and pulled codes PO236, PO237, P1688,
Any help would be appreciated
Thanks
Old Jan 27, 2006 | 02:00 PM
Rammin On's Avatar
Your VP44 is toast ... as is your MAP Sensor
Old Jan 27, 2006 | 03:36 PM
crazylunker's Avatar
does your tach move when cranking? poss crank sensor. hook scanner back up and check for tach signal.
Old Jan 27, 2006 | 08:26 PM
JTBbudman's Avatar
Cant hook it back up, borrowed the scanner and had to give it back. It wasn't diesel specific had to use a generic type obd-II code to pull what info I got. Also just for the record it was a Mac tools Master Tech, not what I previously stated. Also would the comp box cause the MAP sensor problems? I have never checked the codes so I don't know how long they may have been on there.
Subliminal
Dec 15, 2010 04:35 PM
ado2b1
Dec 16, 2008 03:19 PM
flat tire
Jun 15, 2007 10:53 PM
thanasi
Jan 15, 2007 09:53 AM
halerazor
Jul 29, 2004 04:35 PM
