Truck Wont Start :(
Truck Wont Start :(
Hey everyone,
My truck is a 2006 2500 5.9L and hasn't started in about 4 weeks. batteries are fully charged.
Here is what I have replaced -->
I have readjusted the valve lash in spec and checked for leaks.
I'm at a loss of what can be left.
I'm hoping someone here can help me figure out what else is left to check.
Thanks in advance,
Zach
Here is a video of me trying to start her. --->
- Fuel Pump
- Fuel Filter
- Pressure Relief Valve
- Heating Grid
- Intake Heating Relay
- Injectors and Tubes
- Injector Pump
- MAP Sensor
Thanks in advance,
Zach
With the key on run do you have +5V at the sensor supply?
Sounds like a sensor supply issue to me. If you have the +5V you can use a paperclip to short +5V to signal on the map sensor plug, this will also set codes but the truck should start if that was the only issue.
Thanks guys! I got it! I changed the crankshaft and camshaft position sensor a and made sure all the connections were good and is he started up! Thanks for all the help!!
longdude17
Nov 16, 2009 11:20 AM
