truck won't start
Old Nov 30, 2002 | 10:52 AM
bdog's Avatar
truck won't start
This morning when I fired up the truck it cranked for about 10 seconds before it started. It usually fires right up. I drove to the convience store, shut it off and then tried to restart and nothing. It cranks fast but does not fire. I cranked for about 10-15 seconds, then waited, cranked again, and again, and again. Finally it started and ran fine. I drove it home, shut it off and tried to restart it just to see if it would work and it would not. Any ideas? Bad lift pump maybe?
Old Nov 30, 2002 | 12:29 PM
Alan_Reagan's Avatar
Re:truck won't start
Sounds like a bad lift pump or worse a VP44 going bad. One quick way to check the lift pump is the open the water drain valve and turn the key on. It should pump a lot of fuel out of the drain hose. If not it's probably the lift pump. You really need to test the pressure from the pump if possible.
Old Nov 30, 2002 | 04:46 PM
Bushy's Avatar
Patron Saint of 1st gens
My guess is the crank position sensor is nackered.<br><br>bob.
Old Nov 30, 2002 | 10:42 PM
bdog's Avatar
I opened the valve to drain out the water and I hafe fuel there, but I have no idea on pressure. Please give me more info on this crank position sensor. I have never heard of it. What do I need to check?
Old Dec 1, 2002 | 12:05 AM
pwabbott's Avatar
bdog, there is an tech article on this forum site on the Crankshaft Position Sensor.<br><br>http://www.dodge-diesel.org/articles/cps/ckp.htm<br>Hope this helps. ???
Old Dec 1, 2002 | 09:12 AM
tmiller24's Avatar
95 has a shutdown solenoid that sometimes hangs up, don't know what shutdown arrangement is on yours, but its worth a look.
Old Dec 1, 2002 | 03:04 PM
bdog's Avatar
I am not positive but I don't think it is the CPS. The Tach works fine. According to what I read if the CPS went south my tach would not be working properly. As to the shutdown down solenoid I have no idea on that one. Where do I look? What really gets me about this problem is that it comes and goes. Right now if I tried to start my truck it wouldn't but if I jacked with it for a while turning the key off and on and tried to crank it several times eventually I could get it to go. Then it would be running just fine but if I shut it off and tried to restart it a second later it probably would not start.
Old Dec 1, 2002 | 03:20 PM
AlpineRAM's Avatar
Did you get the codes read? <br>Maybe someone can chime in on how to do this on a 2001. ( I think it's about cycling ignition on off 5 times- then read the codes in the odometer or by flashes of the check engine light ??? )<br>Good luck!<br>AlpineRAM
Old Dec 1, 2002 | 03:21 PM
bdog's Avatar
I checked for codes and it is not showing any.
Old Dec 1, 2002 | 03:28 PM
MnTom's Avatar
bdog<br>Just a suggestion- Mine did something similar to what yours is doing and it turned out to be a loose fuel line on top of the fuel filter. I found it one day when I was changing the filter and bumped the line and it moved. I tightened the bolt and it is good now.<br>Tom
Old Dec 1, 2002 | 03:33 PM
bdog's Avatar
Thanks for the reply Tom. I will go out and check that as wells as look for loose connections elsewhere.<br><br>Still sitting at home with a broke down truck. I was really liking my dodge but with my old truck at least when it broke down I was able to figure out the problem and fix it myself.
Old Dec 4, 2002 | 01:53 AM
Bushy's Avatar
It may be cold comfort now but soon you'll enjoy the challenges of these things. I know, it sucks when it's not working and you don't know were to look, but hang in there you'll find the solution.<br>&quot;...Remember, if the women don't find ya handsome, they should at least find ya handy.....&quot; Red Green.<br><br>Bob.
Old Dec 10, 2002 | 09:44 PM
rienerj's Avatar
Is this problem fixed yet? I do believe I have the solution, correctly.
Old Dec 10, 2002 | 10:07 PM
bdog's Avatar
It is fixed. the dealer found a weak injection pump and replaced it under warranty at 67k miles.
Subliminal
Dec 15, 2010 04:35 PM
ado2b1
Dec 16, 2008 03:19 PM
Machinos
Mar 16, 2008 01:34 AM
