Truck Wont Run!!!help,please!!!!
Old Oct 4, 2006 | 02:48 PM
coontz0473's Avatar
update!!!
Originally Posted by donhov
Just a quick note, Yes if the lift pump failed the truck, even though it was running fine, will just out of the blue quit running. Call Chrysler customer care hotline, it's in your owners manual, explaining the millage etc and they will tow it to your closest dealer for repair. Next, if it is the lift pump which it sounds like it is, it is located on the side of the fuel filter canister, will be removed and relocated to the in tank pump, takes about 1 day for repairs if parts are in stock, and whatever time for parts if not in stock. Don't be suprised if about 1 month later a similuar thing happens and then it will be the injector pump, the CP3 pump, as starving the cp3 with a failing lift pump usually causes the cp3 to fail also. On your 04.5 it should be covered under your "ENGINE" warranty, under 5 years and under 100K no deductable over 5 yrs under 100K $100 deductable. Dealer will try to put you under the 7yr/70K ($100 deductable) but read your owners manual and under the engine warranty it states amongst other things fuel pumps, injectors engine crankshaft, pistons and so on. Stand your ground if they try the $100 thing and call Customer Care who will confirm no charge.
Good luck but get it to the dealer, unless you want to install a Fass or like system on your own.
Thanks guys for all the replies and comments!!
It has been at the dealer all day today and finally a call with prognosis. It is as donhov as said "lift pump", although the dealer insist on calling it a "transfer pump". The replacement will be the in tank kind and he doesn't have the parts nor does his warehouse ......he says it will be at least Fri., maybe Mon. before the parts arrive.
I sure hope my cp3 doesn't fail in a month. I posted a question about mpg a few days ago. I had suspicioned something was going wrong as my mpg had decreased in the last 3-4 tanks with no changes to anything. Could this have been this lift pump going out on me?? Or am I just grasping at straws?? Anyway a big THANKS to everyone. You guys are the best.....I'll let you know when the truck is back home...Thanks again!
Sarajaye
25
Feb 26, 2013 03:00 PM
12valve1/2ton
13
Nov 23, 2011 02:09 AM
slowflyer2112
Mar 18, 2010 09:56 AM
Stroked-Z
Oct 4, 2008 11:28 AM
nvillagrana
13
Aug 20, 2006 05:13 PM
