Truck will not start
Old Mar 4, 2008 | 02:05 PM
bighornrmk's Avatar
Pulled truck in garage last Thur. to install S.B. clutch. Just finnished this morning. Got in truck to start, would not start. Fass pump was not running. Wiggled some wires and started pumping. Tried to start again. Started, ran about 10 seconds and died. Drained factory filter, no water. Drained fass unit, no water. Still no start. Fuel pressure 15# with key on. When I crank it over, fuel pressure go to zero. Turn on key, open drain on factory filter, lots
of fuel coming out. Still no start. ANY IDEAS on what to try next.
________________________
06 4x4 6speed Quad cab 3500 SRW 3.73 FASS 150 Quadzilla ZXT Quadzilla commander w/fuel pressure Amsoil by-pass
Old Mar 4, 2008 | 02:16 PM
dozer12216's Avatar
Just choke it a bit, should start right up.
HA!
You completd the clutch install. Right?
Has it accumulated any codes?
YOu have rechecked everything around the clutch area of work!
Could the crank sensor got damaged/disconnected or perhaps the pump.
Oh! Fill out sig so we know what dealing with.
Old Mar 4, 2008 | 03:24 PM
Dennis x3's Avatar
More than likely the brushes on the FASS system are gummed up. Be careful when you pull them out clean then with alcohol and reinstall and that should do it.
Old Mar 4, 2008 | 04:20 PM
bighornrmk's Avatar
DOZER
clutch install complete. NO CODES. Rechecked around clutch area, everything looks good. Only wires that were disconneted were the two on the trans. and they are hooked back up. NO work done near crank sensor or pump. Everything looks good around them.
Old Mar 4, 2008 | 05:27 PM
bighornrmk's Avatar
Found the problem. When I reconneted the negative cable on the driver's side battery , there is a nut on each side. There were wires hiding one nut. Tightened it up , truck runs now. Now the nut behind the wheel can drive it and see how the new clutch works. Thanks for the replies.
TXJClark
Dec 6, 2014 05:50 AM
Hunky Dory
May 13, 2013 08:09 PM
FirstGen1991
Dec 22, 2012 04:24 PM
CoolumConst
Oct 11, 2008 10:00 PM
loosendend
Sep 4, 2006 12:01 PM
