Truck will not crank, engine light flashing
Old Aug 18, 2012 | 09:08 AM
MorganMech's Avatar
Need some help with this one. Truck has sat for about 2 weeks. Went out to start this morning and.....nothing. Check engine light is flaching, but wont turn over. Also noticed that it isnt showing tranny gears on dash?! Help?!
Old Aug 18, 2012 | 09:43 AM
jhenson's Avatar
Dead batteries.....ECM lost power? Disconnect batt connections and reconnect and see if that does anything. Try moving shifter through the gears and then back to park....just a thought.
Old Aug 18, 2012 | 03:17 PM
Bark's Avatar
Like jhenson said. If it was running when you parked it disc the batts for a few minutes (clean the terminals while you are at it). Check the batteries and if you have a batt charger charge em.
If not after reconnecting get a jump and let em charge for a couple of minutes and see what happens.
Thats all I know how to do.
Robert373
May 9, 2012 11:53 AM
EClancy
Dec 24, 2009 06:19 PM
04 SO CA
May 13, 2004 11:31 PM
04 SO CA
Apr 24, 2004 03:27 PM
dodgeboy59td
Jan 6, 2003 07:47 PM
