low oil pressure
Old Aug 16, 2012 | 08:20 PM
wrenchin's Avatar
low oil pressure
i have this 2003 24v in the shop right now it only has 7psi of oil pressure at a idle and 20psi at about 2000rpm. i cant find the problem any ideas?
Old Aug 16, 2012 | 09:21 PM
kthiemann's Avatar
Have you verified that reading with a mechanical gauge? The sending units on these are bad about going out.
Old Aug 17, 2012 | 01:41 PM
wrenchin's Avatar
yeah i dont trust anything elecrtical
Old Aug 17, 2012 | 01:52 PM
Bark's Avatar
The shop should have had time to put a guage on it by now. Any news yet?
Old Aug 17, 2012 | 02:13 PM
wrenchin's Avatar
yeah the readings i took were with the manual guage at the topof the oilfilter housing it is supposed to be a new reman engin that the customer put together himself. so flyin blind here just double checking everything and runnin out of options.
Old Aug 17, 2012 | 02:45 PM
Bark's Avatar
Dang. Thats the only thing I know how to do. Hope this doesnt get expensive.
Wonder what happened to the original engine?
Old Aug 17, 2012 | 02:54 PM
wrenchin's Avatar
filled up with gas then it just quit thatsthe story that i got
Old Aug 17, 2012 | 05:28 PM
patdaly's Avatar
Pickup tube loose/cracked, relief valve jammed open, worn oil pump, diluted oil, worn bearings....
Probably easiest to check the relief first, top of filter base, pull plug and spring and check.
Old Aug 18, 2012 | 06:42 AM
vrtical's Avatar
Don't think much else can go wrong with it. Low oil pressure usually means either bad gauge or pump. Might be cheaper to pull pan now than pull the engine later. IMO
Old Aug 18, 2012 | 09:02 AM
jhenson's Avatar
Low pressure can also be a sign of bad crank bearings. If owner put wrong brgs in (doubtful) or didn't correctly torque bearing caps a loss of oil pressure will occur. That's probably worst case scenario though. Better bet is the check valve for the oil pump or a loose pickup tube as previously mentioned. Hopefully nothing from the oil filter came loose and stopped up the oil passages.
Old Aug 18, 2012 | 09:38 PM
kthiemann's Avatar
Another thing to look at it if the check valve doesn't work is if someone didn't clean the area around the pick up tube properly.
bc3
Dec 1, 2007 10:19 PM
Power Ram 250 C
Feb 20, 2007 11:08 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
Cummins600
Jun 27, 2005 11:37 PM
