truck dies
Old Jun 28, 2005 | 06:20 PM
strokerSmoker's Avatar
truck dies
my truck dies with the ac on. it does not do it when its in park, it only does it when its in drive and im stopped. if i turn the idle up to where it wint die then the truck is idled up way too high.. any suggestions or comments would help. thanx
Old Jun 28, 2005 | 06:50 PM
warwagon97's Avatar
it sounds to me like you need to turn your idle upit is the screw on the drivers side of the pumpit shoul idle at 750 in reverse with ac on full hope this helps
Old Jun 29, 2005 | 06:40 AM
zookeeper's Avatar
I was having the same problem - it died whenever I went to reverse. The idle was just below 500 rpm. Warwagon is right. The book says to place the low speed idle at 750 - 800 rpm when in drive with the AC on.
I adjusted mine last night because I was tired of it stalling out. Before I adjusted it, I used the 2 foot method and gave it a touch of fuel. This worked fine for me but the wife drives it too. It seems about once a year this needs to be adjusted. Last time, I cheated and used it as an excuse to put some injectors in If I had the cash, I'd have done the 3 GSK this round
The low idle screw is VERY sensitive and it doesn't take much at all to raise the idle. The toughest part is to ensure when you tighten the lock nut, you don't "readjust" the idle. I have to go and readjust mine this weekend because it's idling at about 950 rpm - livable because the stalling is stopped. Good Luck!
Old Jun 29, 2005 | 09:14 AM
infidel's Avatar
Idle adjustment instructions http://dodgeram.org/tech/dsl/adjustm...d_Gen-Idle.htm
vintovka
Apr 30, 2012 12:38 PM
90 power ram
Oct 6, 2011 08:04 PM
DynamicalyUnstable
Nov 13, 2008 09:36 PM
Mark3682
Mar 24, 2004 10:59 AM
AZGEARPRO
Aug 19, 2003 12:42 PM
