Trouble shifting gears when truck is warm
After I drive my 2001 6spd for a while I have trouble getting into gear at lights or in to reverse.
I have 73,000km, trans oil has been changed. If I shut truck off trans shifts fine. Any help
Thks for any info
Thks for any info
Sounds like the clutch is starting to grab a little, that could be the master, slave, shift fork , though out bearing[ most likly] clutch. I don't know if your truck has ajustable clutch linkage , which if it does than that will give you more life before replacement.
Originally posted by Larry R
sounds to me like the pilot bearing in the fly wheel is frozen
mtb1982
55
01-20-2020 10:45 AM
