Tranny problem!
Tranny problem!
Hello I have a 98 12 valve 4x4 with auto trans 95,000 miles. This morning I put the truck in reverse to get out of the garage and it sliped. It worked fine in all foreward gears. I got to work and now have no reverse at all. I can feel it engage, and the linkage looks to be well adjusted. the only mod I have is 4inch exhaust.
to check the rear band adjustment its just a pan gasket. most auto parts stores will have that. if the rear band is broken than the trans will have to come out and a total tear down to get to it. if the rear band is ok than it will be in the OD section. that is in the extention (rear )housing. that takes special tools to repair and without them is a dangeris job as there is an 800 lb. spring inside.
bill
bill
Black Dog
Dec 3, 2009 08:18 PM
high bid
Aug 2, 2007 06:08 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
mikie1234
Dec 25, 2004 12:54 AM
silverram323
24
Nov 9, 2003 07:48 PM
