tranny or injection pump?
Old Oct 4, 2008 | 09:31 PM
Blacksunshine's Avatar
hello to all, I just discovered your forum and there seems to be a lot of helpful ideas from fellow dodge owners so a little help would be much appreciated. My '99 dodge 24v auto has a stumble or jump at 60 to 70mph, when you let off a little in a corner and ease back in to it. When you poor the coal to it it's fine, got a gauge on the lift pump (12-6 psi) and no codes show for the TPS or anything else. so if anyone can help me figure out if it's the converter locking and unlocking or the injection pump stumbling would be great, Thanx guys.
Old Oct 5, 2008 | 04:58 PM
wreckere022002's Avatar
my guess would have to be your converter or even try your batt termanals conectons that would make the relay cut on and off thats the best i can give you
Old Oct 5, 2008 | 06:24 PM
ok, thanx for the input i'll try the batteries but yer probably right.
Old Oct 5, 2008 | 07:09 PM
VAautotech's Avatar
i would imagine converter also, put the tranny in tow/haul mode or shift into a different gear if possible and see if anything changes
Old Oct 5, 2008 | 07:29 PM
scottsjeeprolet's Avatar
With the stock trans programming when you let off the throttle the TC unlocks then when you get back on the throttle it locks again. That could be your problem.
Old Oct 5, 2008 | 08:03 PM
it still does it with o/d off at around 17 - 1800, and i didn't think i let off enough to unlock the TC, but maybe. It's my first auto diesel had 6 manuals and this one i got used so not sure if it's just the way the tranny is or if theres a problem. anyways thanx guys
tommurray
Feb 23, 2014 10:38 AM
Black Dog
Dec 3, 2009 08:18 PM
adgr71
Nov 28, 2005 07:34 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
cheng
Jun 22, 2004 12:01 PM
