torque converter unlocking
Old Jan 11, 2007 | 09:23 PM
glenn-k's Avatar
Anybody ever have trouble with the connection plug on the top of the transmission. I just put on a new Suncoast Valve Body and they mentioned that you should put di-electric grease on the terminals to prevent corrosion.
Old Jan 11, 2007 | 10:17 PM
TurboCrisco's Avatar
Your TPS can be adjusted also before you decide to toss it . If it is not sending the correct voltage it will unlock and lock and drive you crazy. I still havent got mine right but am on the right track I hope. Check out the link below. I drilled out the mounting holes like in the article and it will adjust the voltage(clockwise to increase). Check it with meter hooked up and tighten it down when you get it to 1 volt or so. I was able to get a reading by sticking the meter probe into the center of the plug where the wire goes in and not shaving any wire insulation. I had initially drilled mine and cleaned it out with contact cleaner but it seemed to continue to work better when cleaned initially then spraying wd40 through the holes. Then I took the entire thing apart too see what made it tick, not much there for 180$ for sure. Ill go and buy one of the Radio shack potentiometers before Illl pay that kind of money for a 10$ part. It takes time and is a pain but hopefully youll get it right and maybe learn something in the process.
http://dieselgiant.com/dodge_diesel_...nance_tips.htm
Old Jan 24, 2007 | 08:38 PM
kwillis-a's Avatar
thanks guys for all your input. i took the tps off and cleaned it with some breakclean, put it back on and it works perfectly now. i really do apreciat the help.
Old Jan 24, 2007 | 09:56 PM
mr T's Avatar
hey I'm moving to FL in september...pompano beach...hope u still got ur truck by then!
CTD2001
28
Mar 16, 2023 03:58 PM
Pendo2006
May 26, 2006 07:09 PM
Foothill-Trader
Jul 17, 2005 11:08 AM
nitrousn
May 10, 2004 12:01 PM
