timing is going crazy.... help please!!!
Old Apr 30, 2008 | 09:26 PM
Ramdriver15's Avatar
i checked the timing today and it was at 30 degrees.... found tdc by removing the #1 injector and using a screw driver top show where the piston is.
marked it and then zeroed the dial indicator and found the timing to be 7.8 mm of lift= 30 degrees.
i then set the lift to 5.0 and removed the timing gear from the pump. i then returned the truck to tdc....
when trying to start it did not. we used either to get her rolling and found it to not like to run and after the 4 foot flame that decided to ignite out the stack i rechecked the timing. it was at 1.9mm...
i reset again to 5.0 mm and when i femoved the gear i found that the cam in the pump sprung to 1.9mm again..... why is the pump springing to different setting when the ghear is removed, anyone know how to get it to stop doing this?\\
truck is downed in the driveway for the night... i need her back asap....
Old Apr 30, 2008 | 09:49 PM
help help!!!
Old May 1, 2008 | 02:54 PM
REF>Lancer's Avatar
Any big bang when this problem started? maybe a gear?
Old May 1, 2008 | 04:12 PM
Did you clean the shaft and gear real good with contact cleaner spray?
Old May 1, 2008 | 06:36 PM
pump was 180 out
Old May 1, 2008 | 08:52 PM
BigIron70's Avatar
Cummins Guru
Smile
If you still need procedure for setting the timing let me know and I will post it for you.
Old May 1, 2008 | 11:11 PM
i have the procedure.... ive set three or four trucks now, i had mine up at 30 and it got all jacked around when i was trying to get it reset. its ok now... called EEP and got some info that was redudant of what i knew... just had to take my time
dieselfan
40
Jan 19, 2007 06:30 AM
KristinaWitt
Oct 11, 2006 03:26 PM
Atlantic4x4
Sep 8, 2006 09:20 AM
MoparRiggan
Jan 17, 2006 12:43 PM
