stranded 450 miles from home HELP!!!
My 99' in my sig died on me 450 miles from home and wont start, took chip and programmer off and still wont start, programmer picked up codes p1688, and p0252, is there any hope, checked fuel filter that was changed 2k ago and still looked clean, any tips on what to check for???
The 1688 tells me you are dead in the water, its pump time, and it had to happen away from home.
0216 has been regarded as the death code, but it is only the code of impending doom. the death codes are 1688/1689. those are where the pump is done, time for replacement.
Good luck with it, at least you're only 450 miles from home.
If you're decent with a wrench you can have the pump swapped out in couple of hours, otherwise maybe hit someone up in the AZ chapter to see if they'll lend a hand.
There is a Perkins Diesel shop in Mesa, PH# 480-964-5273. They're a Bosch certified dealer.
1688 is internal fuel injection pump controller failure.... the electronic control module on the VP 44 has died, the only way to fix it is replacement of the VP44
i did some research and found mazda has the 1688 definition annabelle listed
here's the one i use
http://www.troublecodes.net/articles...e_reader.shtml
Bluetek
39
06-14-2010 09:19 PM
jmccart
48
07-23-2008 12:34 AM
2500TurboDodge
07-31-2006 04:21 PM
