starts & shuts off
Old Nov 17, 2006 | 09:27 AM
scroshba06's Avatar
starts & shuts off
Please Help. I Put A New Lift Pump & Filter In. Now Truck Runs For About 3 Sec's And Shuts Off. Restart And Turn Over For About 10 Sec's And It Fires Right Up And Runs Fine. Confused About What To Look At Now. its a 1999 ext cab 2500 4x4 sb
Old Nov 17, 2006 | 10:08 AM
BC847's Avatar
1st Generation Admin
Did you purge all the air from the fuel lines and filter after the pump/filter change?
Fill out your Sig (under User CP - top left) and put what year truck, trans, etc, so those wanting to help, will know what you're messing with.
And welcome to our forums.
Old Nov 17, 2006 | 03:29 PM
scroshba06's Avatar
i got all the air out. this is going on day 3 like this.
Old Nov 17, 2006 | 04:51 PM
John Faughn's Avatar
Fuel Pressure test ?
Before any parts .
If the lift pump went out then it may have damaged the VPump .
Old Nov 17, 2006 | 06:13 PM
jrs_dodge_diesel's Avatar
Sounds like you didn't seal up the filter lid or something just right, and is letting air in. I would double check everything that you loosened up and make sure it is sealed good.
bmcdowell40
Mar 1, 2013 09:56 AM
Eng111Lt
0
Jan 3, 2012 12:43 PM
97catintenn
Jan 7, 2010 11:33 PM
Pontiac puller
Nov 9, 2003 09:22 PM
TheMoose
Oct 31, 2003 12:06 PM
