Squeling Noise Please Help
Old Jan 13, 2008 | 12:20 PM
06farmtruck's Avatar
I have a 06 drw with 6 speed and 4x4 with 25k . I was hauling my 3 horse trl. at about 3000 rpm and started hearing a squeling noise coming and fadding out. Dodge said it was the clutch and changed but i still hear the noise. I happens when i hold it at 65 or 70 and keep it there for awhile. It almost sounds like a bearing going out. Please help guys. Seeams like you all know you stuff Thanks
Old Jan 14, 2008 | 10:59 PM
TruckU's Avatar
How many miles? Did the dealer put a new belt on or use the old one? If the belt is old and glazed over it will squeel pretty bad. I thought my Alternator was going out, but was told to change the belt, and it's been fine since.
Good luck
Old Jan 15, 2008 | 09:04 AM
strokerace's Avatar
The belts probably a good place to start. I had some squealing noises a while ago and thought I had a bad pulley or something but I got a new belt and the noise went away. If that doesnt fix your problem then at least you have a spare belt on hand. Good Luck
Old Jan 15, 2008 | 11:20 AM
Clayten's Avatar
DTR's Toad Wrangler
Could that be the belt tensioner? Seems pretty new for that to be happening but it might be.
Old Jan 15, 2008 | 12:13 PM
torquefan's Avatar
It's not common, but maybe the A/C compressor was starting to seize up, and was squealing the belt as it cycled in and out.
Old Jan 15, 2008 | 02:19 PM
Busboy's Avatar
As you have a std trans the problem is not RPM related it's as you say speed related. First ck the oil in the transfer case, the oil qty is so small just a small leak will cause you trouble, also the rear axle oil qty. Next wheel bearings then rear drive shaft hangar bearing. Two long shots would be a vacuum leak (they sure do squeal) or the clutch fan hub bearing.
Old Jan 16, 2008 | 03:26 PM
Thanks for all the suggestions
Old Jan 16, 2008 | 08:40 PM
TIMMY22's Avatar
I just had the problem today. It was my a/c compressor.
Ended up buying a belt for a no AC truck. Now my a/c compressor is not connected and no squeel, waiting for warm weather to look into it.
97dodgeram2500
May 22, 2009 09:32 AM
06farmtruck
Jan 17, 2008 04:25 PM
SuperiorRam
Mar 15, 2007 03:10 AM
QWKRTNU
Oct 24, 2006 08:23 AM
barn6720
Mar 30, 2006 12:04 AM
