squeling noise
I have a 06 drw with 6 speed and 4x4 with 25k . I was hauling my 3 horse trl. at about 3000 rpm and started hearing a squeling noise coming and fadding out. Dodge said it was the clutch and changed but i still hear the noise. I happens when i hold it at 65 or 70 and keep it there for awhile. It almost sounds like a bearing going out. Please help guys. Seeams like you all know you stuff Thanks
Could it be in the rear diff?
I had this and going up to 75/140 gear oil (syn) from 75/90 seems to have fixed it. No noise any more. It only happened with a load going up hill and pretty heavy throttle.
Cya
Cya
Seems to be coming from the front
It seems to be comming from the front. And now it does it any time loaded or not. At firt they said it was a winshield leak. LOL They were supposed to be calling STAR but now they wont anwser my call.
Two things you might also check.... Alternator bearing...Just replaced mine this weekend and it was squealing, although slight I could hear it, and then what about the belt tensioner and bearing? I have not heard that these are an issue in the CTDs, but I have had this issue on others.
I've also got a squealing in mine (all the time though). Can't pinpoint where it's coming from.
Mr Bee, what exactly did you replace on your alternator? I've seen a TSB out for 3rd gens that replace the pulley with a free wheeling (in one direction) one to prevent a chirp at shutdown as well.
Can the belt tensioner pulley bearing be replaced by itself, or do you have to buy the whole darn thing?
5.9.... I replaced the entire alternator becuase the charging rate dropped to about 10V.... Not good! BTW... these are not cheap to replace...
A re-manufactured alternator for $190.00. It also started giving one of my batteries issues (Pucking out acid out of the vent) but once alternator was changed all is well .
Do you know the tsb number I went to the dealer and they had no clue about the tsb. Mine has been squeaking since 3K and I have 18k on it now. They replaced the belt and alternator so far but it is still there.
Smkn600CTD
May 22, 2012 07:21 PM
97dodgeram2500
May 22, 2009 09:32 AM
ShowMe06
27
Jan 4, 2008 11:47 AM
