HELP Autometer Oil pressure gauge noise please help!!!!
Old Oct 11, 2006 | 08:37 PM
QWKRTNU's Avatar
I got a mech oil gauge and it makes this hum noise when i let off the gas or apply slight pressure to the throttle. Anyone else have this issue??? Or is it a bad gauge. Thanks
Old Oct 12, 2006 | 01:03 AM
QWKRTNU's Avatar
no one know anything
Old Oct 15, 2006 | 02:35 PM
QWKRTNU's Avatar
one last try. Anyone have noises with any gauges
Old Oct 15, 2006 | 02:52 PM
trik396's Avatar
I don't have mechanical guages but I'd guess your getting the vibration directly from the engine thru the oil hose...?
Maybe there's some sort of "snubber" or isolation piece you can add to the hose to reduce the hum. Good luck.
Old Oct 15, 2006 | 02:54 PM
trik396's Avatar
I had mechanical Autometer guages in my old hot rod.... But I couldn't hear anything because it was a mechanical lifter, 509cubic inch rat with dual 3.5" exhausts dumped right before the rearend... Talk about rumble...
Old Oct 15, 2006 | 02:56 PM
QWKRTNU's Avatar
I know it is the oil becasue I disconnected it and it was gone so it sucks. Is sounds like I have a hum like the guys with the dicol boost gauges. Maybe putting rubber hose along the whole oil line. But the trans and fuel work great.
Old Oct 15, 2006 | 02:59 PM
cmnspwr's Avatar
Have you got a 1/8" nylon hose, or braided stainless running to the gauge?
Old Oct 15, 2006 | 03:01 PM
QWKRTNU's Avatar
I got brass line. Have had nothing but problems with the clear crap that comes with it.
Old Oct 15, 2006 | 03:02 PM
trik396's Avatar
My guess is your brass line is absorbing alot of harmonics from the Cummins and transfering them to your guage... Just a guess.
Old Oct 15, 2006 | 03:04 PM
QWKRTNU's Avatar
Im not sure. I have always ran copper tubbing to all boost and oil gauges before. But this is the first diesel i have done this too
Old Oct 24, 2006 | 12:12 AM
QWKRTNU's Avatar
I ran fuel line over the brass line from the engine to the gauge and it is gone. So if you run brass cover it in fuel line no more noise. Thanks for all the help.
Old Oct 24, 2006 | 08:23 AM
trik396's Avatar
ado2b1
Jul 6, 2007 10:27 PM
rjm022
15
Feb 3, 2006 09:35 AM
ASTAR
18
Feb 3, 2006 09:27 AM
Buckshotmckee
Jan 27, 2005 09:48 AM
pmtg
Jan 17, 2004 01:08 AM
