She cranks but, no fire.
Old Dec 19, 2006 | 03:58 PM
zc4life's Avatar
new to the diesel scene. I drove the truck this past weekend without a hitch. Yesterday, however, it cranks but I have no fire. Any advise?
Tree
04 ram 3500 dually. approx 92,000 miles
Old Dec 19, 2006 | 03:59 PM
Clunk's Avatar
What year Dodge are you referring to?
Old Dec 19, 2006 | 04:01 PM
zc4life's Avatar
04 3500 4x4 dually
Old Dec 19, 2006 | 04:17 PM
runamuk's Avatar
Check your codes? If not check them and tell us.
Rick
Old Dec 19, 2006 | 04:20 PM
Clunk's Avatar
Does the keyswitch trick work on late model trucks too?
Old Dec 19, 2006 | 04:23 PM
runamuk's Avatar
Yes it does
Old Dec 19, 2006 | 04:24 PM
dodgezilla04's Avatar
yes it does.
do you hear the lift pump running? when it is cranking, any sputtering(attempting to run) at all?
are you in a VERY cold area, and maybe the grid heaters are not working?
Old Dec 19, 2006 | 04:25 PM
runamuk's Avatar
Colorado, Is Butt cold this time of year!!.............. could be the fuel is gelled??
Rick
Old Dec 19, 2006 | 04:39 PM
that is a good possibility. i wonder if this nice gentleman is using any form of additive. Being that he is new to the diesel scene, i hope he can located the LP, since it is an 04, i am gonna assume it is still on the filter housing and hasnt been relocated to the tank. we will have to see if he answers back with the grid heaters, and attempts to fire. thanks rick
oh yeah, welcome to DTR
Old Dec 19, 2006 | 04:43 PM
runamuk's Avatar
DUH!! WELCOME TO DTR Zc4life!
Rick
Old Dec 19, 2006 | 04:51 PM
we are slipping arent we rick? that took us 9 posts to get with the program. back to training we go.
Old Dec 19, 2006 | 07:37 PM
zc4life's Avatar
Sorry fellas, I have been working on it. Where can I find the codes? It's very cold right now. When I crank it, it trys to fire. Thanks for all the humoruos help.
Old Dec 19, 2006 | 07:53 PM
zc4life's Avatar
Okay, after much reading. The codes are P0483
Old Dec 19, 2006 | 07:56 PM
runamuk's Avatar
Turn the key to the on position and then off 3 times (Do not crank) the 3rd time the codes will be displayed in the odometer.
Check your fuel filter to make sure that you have liquid fuel instead of gelled. Look for yellow switch on bottom of fuel filter canister(drivers side) drain some fuel to test.
Rick
Old Dec 19, 2006 | 07:58 PM
zc4life's Avatar
I will check the fuel filter.
