shake stop
shake stop
does anybody know what the deal is with my truck shaking when i stop are the rotors warped or what and how can i fix or upgrade it?
it seems like it gets worse everyday!
Is the front shaking or the rear??
Do this on a road that is straight and not much traffic,, Speed up to about 60 MPH,Push the brake pedal slowly and take note if the steering wheel is shaking,,IF NOT, speed up again and slowly put the E brake on and take note if the truck starts shaking.
Steering wheel shake = Rotors
E Brake shake = Rear Brake Drums
Hope that helps..
B
I tried that and it seems that it is in deed coming from the back so i guess it is the drums,
How hard is it to adjust the e-brake, mine is very lose and want hardly hold the truck back on a hill?
mine does the front end wobble a little bit. however every single part is brand new on the front end. its being aligned this afternoon. short answer, if your fronts are not in line, you can get some wobble and some bump steer.
i should make a note, after having alignment done yesterday, drives straight as can be, however i stil lhave a small shimmy when i brake hard. When it was on the rack they showed me a small amount of play in pass side bearing, which i need to look at this weekend. could just need to be tightened im not sure.
Here is a kicker went to the shop this weekend to scope the deal out about the brake job and to my surprise it is no wonder my e-brake doenst work and it shakes when it stops all i have stopping it is front brakes because both left and right rear brakes where completely coverd in rear end oil, so i guess i will have to replace both seals now with a brake job......
slivertruck
25
Nov 8, 2006 08:35 PM
royta
Nov 6, 2006 08:19 AM
