service NV5600 help please quick
Old Mar 13, 2008 | 05:30 PM
Krob's Avatar
Waiting at buddys shop to use his lift dont have a lot of time before he needs it back. How do you drain a NV5600 transmision. I dont see a drain plug each side has a plate do you loosen one of those??? Which one if that??
Thanks Rob
Old Mar 13, 2008 | 05:37 PM
dozer12216's Avatar
Bottom hole on plate is drain!!!!! Either side. Remove plate to inspect.
Old Mar 13, 2008 | 05:38 PM
Krob's Avatar
Thanks Rob
Old Mar 15, 2008 | 10:08 PM
Jeff in TD's Avatar
As long as you are doing a fluid change, I'd suggest pulling the plate so you can reach inside and get the magnet off the bottom of the case to clean it.
It's a square flat magnet (photo in my gallery).
RTV the cover back on, with thread sealant on the bolts. Fill plug is 17mm if memory serves...
steelblitzkrieg
Oct 14, 2011 09:19 PM
brianpgriset
Aug 2, 2008 06:50 PM
SuperiorRam
Mar 15, 2007 03:10 AM
dieselbeef
Jun 12, 2006 08:12 AM
HorseHauler
13
Mar 12, 2006 11:48 AM
