help with fuel presure
Old Mar 15, 2008 | 09:21 PM
cabtruck's Avatar
1 have a 04 lost power wont run over 45 i think in has lost fuel presure what shoud it be at the filter befor and after
Old Mar 15, 2008 | 10:01 PM
BigIron70's Avatar
Cummins Guru
Flow test should be 2003 and early 2004 560 mL in 10 seconds, 2004 through 2007 590 mL in 10 seconds. If your pump is mounted to fuel filter housing, replace it with retrofit fuel pump includes everything you need to install pump in tank. Also will need to flash ECM Dodge dealership can do this. Good Luck
Old Mar 15, 2008 | 11:28 PM
cabtruck's Avatar
the truck it acting like it is runing out of fuel but has a full tank
brickenbone
Apr 11, 2007 04:53 PM
bryanburns
Feb 2, 2006 10:55 PM
kingofdodge7131
Apr 30, 2003 11:02 PM
DarrellB
Feb 6, 2003 04:08 PM
