SBC Clutch Wont engage
Old Dec 6, 2006 | 06:22 PM
tristan21's Avatar
I had a SBC DD installed in the truck in feb. and had great luck since.......until last night. While pulling my 24' enclosed trailer to work from missouri to penn. I started experiencing a clutch that wont engage or disengage and it takes both hands to get it into gear and a whole lot of force when stopped. After I get rolling it gets better but definatly not good. I dont know the series of clutch as I am on the road working away from the paper work. I did call SBC and Pete was not there and several of the other guys were not very helpful as I was instructed that they only manufacture clutches and do not install them they could not provide any tech support on the Dodge. I had a reputable(?) shop at home do the install along with the new better hydrolics from the 2nd Gen. I tried adjusting the pedal all the way out on the clutch and that doesnt help. When it does dissengage I get a pop and I have the pedal as hard as I can on the wall. Im gonna try Pete back tomorrow but I would like to have this fixed soon because I will need to pull this trailer back in about 10 days or so.
What can I do or try and does anyone know a good shop or any diesel shop the scranton, PA area???? Thanks in advance any help is appreciated.
Please note that I have up to this point been very happy with my SBC DD.
Old Dec 6, 2006 | 07:04 PM
dieselrob's Avatar
You can try doug at Performance Diesel Warehouse
800-893-1059. Hes down by hershy witch is prolly only 2 hours away. The only other one i know of is down in allentown, but there more into injectors pumps and turbos than anything else.
Old Dec 6, 2006 | 07:57 PM
high country's Avatar
have you lost any fluid? it sounds like a lame master or slave.
Old Dec 6, 2006 | 08:53 PM
Jim Dynomite's Avatar
I'll second that. They don't show any sign when they fail. So just looking at the fluid level is not an indication
I'll bet you anything, that's what it is. The clutch master and slave cylider are a one piece unit from Dodge. It already has the fluid in it and is bled and ready to go when you buy the combo right off the shelf.
Super easy install also.
.......Jim
Old Dec 6, 2006 | 09:19 PM
XLR8R's Avatar
Wonder how much the dealer wants for that set-up... might be a good spare part to have on hand.
Old Dec 6, 2006 | 10:03 PM
You know, that was for my 99. I'm sorry, I don't know if its the same for the 3rd gens.
.......Jim
Old Dec 6, 2006 | 11:36 PM
RickCJ's Avatar
Don't force it!! Shut off the engine and shift it into gear if you have to, you should be able to shift with out the clutch once moveing. Sounds like your clutch or slave cylinder went bad.
South Bend sells a very nice adjustable set up.
Old Dec 7, 2006 | 07:25 AM
South Bend Clutch's Avatar
Vendor - Former Vendor
I am in today so give me a call. I may know what the problem is.
Peter
Old Dec 7, 2006 | 10:02 AM
dodgezilla04's Avatar
regardless of dealership price, i would go with the upgraded hydraulics from SBC. i havent decided yet if i will do it, my clutch seems to be smoothing out really nice.
BigDodgeBigHart
Apr 13, 2007 10:26 AM
BigDodgeBigHart
Apr 13, 2007 09:18 AM
360ramcharger
Jan 2, 2006 03:04 PM
jman6716
Oct 26, 2004 07:40 AM
