Say it aint so
Old Nov 22, 2004 | 09:13 PM
mr T's Avatar
your wires are corroded...check for broken, corroded or exposed wires...they're shorting somewhere...ur tps shouldnt light up the engine light check ur relays...heck check ur battery terminal on ur driver side coould have loose or burnts wires there ..
anyhow when ur locked out of overdrive do u lock up fine in third?? or does it do the same as in overdrive? the tps went on mine shifts fine now...
look for corroded or loose throttle cable and kickdown cable...tps is acting up probably too...ur gonna be gettign alot of corroded wires on that truck im having enough trouble myself but i replaced and fixed all the wires the truck runs like new now just my original speakers and radio is going...crackles
Old Nov 23, 2004 | 02:43 PM
Lil Dog's Avatar
The Crank sensor is located on the top of the balancer bolted to the gear housing. It has a 3 wire plug that is just down behind the fan hub. Check the plug for obvious problems, else inspect the sensor for signs of wear or abrasion from touching the crank. If you can, the tach sensor output is under the dash for the OEM tach hookup. I think the Grey wire is the signal, but if you have the tools you could check for signal there.
I can't remember if there is a code for that or not. The key on-off-on-off-on triggers the Check Engine lite to kick out the code in lite flashes. It will flash a number of times, take a short pause then another number of flashes. Like 5-5 or 4-2 etc. The codes will coencide with a potential problem which might show the CPS.
I will look at the Dodgeram.org site to see if I can find it again.
Old Dec 6, 2004 | 05:52 PM
carl4432's Avatar
You told me to look behind the top balancer bolted to the gear hub for the crank sensor....I'm lost what balancer and what gear hub ..... Near the cooling fan (radiator??)
Old Dec 6, 2004 | 06:10 PM
carl4432's Avatar
Old Dec 6, 2004 | 06:48 PM
MnTom's Avatar
Yep. Stand in front of the truck (with the hood open, of course!!) and look down between the radiator and the engine. The pulley that is on the bottom of the engine is the balancer. On the top of that you will see something bolted to the timing cover and pointing at the balancer. That is the CPS (crankshaft position sensor).
Tom
Old Mar 2, 2005 | 12:03 PM
carl4432's Avatar
Thanks Tom,
Truck is running great now. Crank sensor was it (actually the wire to the crank sensor)
Carl
slothman
Apr 16, 2006 12:20 PM
Geico266
Feb 22, 2006 08:43 AM
mymaur
Jan 22, 2003 02:53 PM
Fishcop
Nov 13, 2002 08:45 PM
tool
Oct 29, 2002 09:11 PM
