safety airbag light.?
I dont know about such things but my manuel says that a DRBIIIt scan tool (whatever that is) is required to figure out what the problem is. Hopefully somebody will chime in with more info. Maybe its not as complicated as the manuel indicates but you should assume that your bag (bags) are not functioning properly until you get it checked out.
I will almost guarantee you it's the clock spring in the column. Just had one replaced on the wifey's car. Airbag light would not go off and then the horn quit working. Clock spring is the culprit here.
lovin1stgens
Aug 31, 2018 09:49 PM
csramsey640
Jan 5, 2011 07:37 PM
Valv
Apr 10, 2005 04:58 PM
yz
Jul 5, 2003 09:10 PM
