Return fuel line and trans
Old Jul 28, 2007 | 12:00 PM
rodsracingteam's Avatar
I have a 1996 ram 2500 cummins with 250k and just replaced the 3/8 fuel line which I got from the dealer, I was looking to replace the 5/16 return from the sender unit to the fuel filter, but dodge is telling me there is no listing(which I find hard to believe) Would anyone know of a place to get this line as mine looks to be on it's way out very soon!
Also is there a cable for the trans to adjust shift points, mine seems to hold each gear unless I let off the pedal. Anything over 2000 rpm from a dead stop and startup, it will not shift out of gear unless I let up on the gas pedal.
Thanks
Rod
Old Jul 28, 2007 | 12:13 PM
vzdude's Avatar
DTR's 'Go to Guy'
It is called the TV cable or throttle vacuum cable. It is adjustable at the pump end, but I usually see the problem under the truck at the linkage on the trans. They get real dirty or bent and bind. First place I would check. As for the 5/16 line, I don't know. but I'll go look.
Old Jul 28, 2007 | 12:20 PM
Ok, I will check the linkage area first. Thanks for the response!
Old Jul 28, 2007 | 12:27 PM
vzdude's Avatar
DTR's 'Go to Guy'
As for the line, Is it the hose right next to the fuel supply line with quick disconnects on either end?
Old Jul 28, 2007 | 12:38 PM
Yes, if you are looking at the top of the sending unit on the drivers side it is the smaller quick disconnect line to the left! That line goes all the way to the filter and has a steel braided flex line factory attached to it.
Old Jul 28, 2007 | 12:45 PM
vzdude's Avatar
DTR's 'Go to Guy'
o.k. stardard cab long bed, short bed, extra cab? PM me your vin so I can get you the right part number.
Old Jul 28, 2007 | 02:09 PM
Reg Cab, Long Bed.
Old Jul 28, 2007 | 04:02 PM
vzdude's Avatar
DTR's 'Go to Guy'
Sorry, parts site has been down a while!
Old Jul 30, 2007 | 11:39 AM
ok, thanks!
Old Jul 30, 2007 | 03:35 PM
VACHZHD's Avatar
Do a search in the 12 valve forum on "fuel line replacement" and read about the options of simply abandoning the original lines and replacing with diesel rated hose from the tank to the engine... seems like the way to go, simpler (and cheaper I would imagine) than buying dealer replacements.
Rick 12v CTD
Sep 23, 2011 05:21 PM
Scotts_D250
Jul 10, 2011 01:05 AM
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
firepiper
Mar 18, 2005 09:11 PM
