replacement lift pump questions on an 03
Old Feb 12, 2008 | 03:33 PM
roxj's Avatar
my truck has been at my local dodge dealer since last wed. ( only 75k miles so its still under warranty) and they finally determined it needs a new lift pump, which they say is not covered by the warranty and will cost $1200. dollars. my truck still has the original lift pump under the hood but they want to do the retro fit and move it to the tank for the $1200. what are my options other than the retro fit? i really dont want to spend $1200 for a pia in tank pump. ive been looking at the fass and air dog 100 set ups. are there any other options that are less expensive? also since its not covered under warrany i will be doing the install my self to save on labor cost. i need to fix this thing asap.
Old Feb 12, 2008 | 03:47 PM
clowndodge01's Avatar
1200 for a lift pump???? wow i just got my airdog in the mail yesterday Im putting it on tonight I've read the instruction book 4 times laid all the parts out looked under the hood and it looks pretty easy with very little common sence, price= $499 shipped
Old Feb 12, 2008 | 08:40 PM
AirGrabber's Avatar
Your lift pump is covered under warranty !!! Regardless of retofit or not. No deductable, no charge. Tell the serice manager that he can call chrysler to verify. Or just take it to another dealer. You can call dodge yourself. If all else fails you can just spend a 139.00 and order a stock replacement lift pump from rock auto or genos. Or upgrade to a better set up. Easy to replace ( about a 1/2 hr). But you shouldnt have to, its clearly stated in your manual and easy for him to verify with dodge. cummins warranty 5yrs 100k.
Old Feb 12, 2008 | 09:57 PM
roxj's Avatar
i called chrysler and two other stealerships and they all said no
Old Feb 12, 2008 | 10:18 PM
shortbed rv's Avatar
I live across 45 in Oakridge North. I just took my stock filter pump off and replaced it with a DIY walbro kit. If you need to borrow my stock pump pm me.
Old Feb 16, 2008 | 11:24 AM
roxj's Avatar
thanks for the offer. i decided to go with the airdog 100. hopefully i will have it in this afternoon. if you ever need help with anything pm me, im only like 5 minutes from you off 45 and 242.
thanks again,
trey
Txwelder
Nov 26, 2025 01:53 AM
mstep3
23
Jul 27, 2010 02:22 PM
TXTad
Jan 6, 2006 10:51 AM
Txwelder
May 19, 2005 06:10 PM
AlpineRAM
Jan 30, 2003 03:24 AM
