rear brake sticking ???????
Old Nov 17, 2008 | 01:42 PM
duallydave's Avatar
hi all,
im having a weird brake issue,i thought all along it was my ebrake stickin,i even installed a heavy spring to make it release better,after removing the wheel and looking closer its not the ebrake at all its the rear disc not disengagaing all the way,when i pry the pad apart the hub moves freely,when i push on the brake pedal and then try the hub again its very stiff,i bled a lil brake fluid out while spreading the pad and ill try that today,it got so bad i could smell the brake rubbing and it was hot,why would the pads not disengage?i cleaned as much as i could from the caliper and removed it and cleaned inside it too,weird,any sugestions?thanx guys
Old Nov 17, 2008 | 01:51 PM
SAVOY1964's Avatar
There are clips that the pads ride on usually they need to be replaced.
Old Nov 17, 2008 | 06:10 PM
GAmes's Avatar
The flexline could be collapsed internally and acting as a one way check valve. It happened to me on my 67 Chev and I'm embarassed to tell you all the parts I replaced.
Old Nov 17, 2008 | 06:13 PM
AirGrabber's Avatar
When you had the caliper off, did you clean everything . Both areas where the pads rest and where the caliper slides should be cleaned very well with a wire wheel or at least a wire brush. Alot of scale will build up and prevent the right amount of movement and cause your brakes to stick/rub.
Old Nov 17, 2008 | 06:45 PM
infidel's Avatar
If the caliper retracts easily with the bleed screw open but hard when closed it's usually as GAmes said, failed hose. Inner layer of hose peels off making a flap that lets fluid flow one way but not the other.
Old Nov 17, 2008 | 06:49 PM
dozer12216's Avatar
Sounds more like it's time for caliper replace. Typical at age you have. Even though can get to retract, they are dragging as your efforts show. Replace both and be done with it for several years again. JMHO
Old Nov 18, 2008 | 01:43 PM
duallydave's Avatar
thanx for the replies,ill take her apart again and totally clean and lube everything,i hope its not the line,would hate to replace that,thanx again for all the tips,this place is awsome
ScreaminEagle
Nov 23, 2011 09:19 PM
ted_pulliam
Mar 12, 2010 01:20 PM
klx300guy8
Apr 18, 2009 10:26 PM
duallydave
Nov 18, 2008 09:56 PM
JP-4.5
Jan 9, 2008 07:54 PM
